Dynamohum, you are doing a fantastic job!
Where did you get that material for ceramic coating? Is it expensive? And how thick is the coating by your estimate? |
Thank you for your kind words, I purchased the Ceramic Coatings from Tech Line Coatings Inc. http://www.techlinecoatings.com/BulkEngine.htm After consulting with one of their Engineers that assured me that the CBC2 Powerkote is able to withstand a comp ratio of 13 to 1 with a boost pressure of 1 bar and 1500 deg/f I decided to go with it over their other Ceramic product CBX, because the CBC2 can be polished. Its not that expensive ($ 24.95) considering a small 3oz bottle, is suppose to do up to 24, 4" pistons The recommended application thickness is .001" thousands of an inch. It is a water based product, high in solids and easy to apply with a small air brush. |
Good Job Paul! Are those stock US or Euro pistons?
Stock US 95mm Motronic pistons 9.5 to 1 CR |
| All times are GMT -8. The time now is 11:28 AM. |
