-   -   What to do? Broken 1970 2.0T Piston (http://forums.pelicanparts.com/911-engine-rebuilding-forum/452918-what-do-broken-1970-2-0t-piston.html)
AgPete139 01-22-2009 10:53 PM
http://img.photobucket.com/albums/v1...6/DSC00453.jpg
Right side of the shortblock:
http://img.photobucket.com/albums/v1...%206/PC456.jpg
http://img.photobucket.com/albums/v1...6/DSC00471.jpg
This is pretty much the condition of all:
http://img.photobucket.com/albums/v1...derWall1_A.jpg
http://img.photobucket.com/albums/v1...4%206/Set1.jpg
http://img.photobucket.com/albums/v1...06/Valves1.jpg
But, this is where the kicker is. I have been EXCEEDINGLY careful and gentle throughout this entire disassembly process with the magnesium parts. I am unsnapping the circlips that hold the wristpins to the pistons and this "piece" falls out onto the garage floor. In the back of my mind, I think, "Oh *****!" but tell myself not to worry. I examine the piece, and instantly realize it's a broken piece of the #2 cylinder!
http://img.photobucket.com/albums/v1...kenPiston2.jpg
So, I'm now in panic mode.
Guys & gals, what are my options?
  • Where I could find another, single, stock 2.0T piston? 80 mm bore, 66 mm stroke?
  • Is JE Pistons a reasonable option (that is in my price range <$1K) ?
  • Stock 8.6:1, but what piston set could will yield a slightly higher compression?
  • I understand that 2.2L pistons share the same crank, and the 2.0 heads need to be matched. How do they do this?
I do NOT want to switch to 2.2L heads though. I am aiming for near stock, and a stock cam.
:confused:
Thanks Pelicans in advance for your help,
Pete
tom1394racing 01-23-2009 03:56 AM
I have a NOS and used 2.0T pistons.
I can also supply a set of used, in-spec, OEM 2.0E or 2.0 normal pistons if you'd like to raise compression.
PM me with your email for pics and prices.
Plavan 01-23-2009 08:29 AM
I think I have a used set of 2.2L pistons. They came out of a motor that lost a valve spring. I'll sell you all 6 for $50 + shipping. (I have to make sure they are 2.2L pistons first- and they are still in the garage.)
Henry Schmidt 01-23-2009 10:51 AM
If you are interested we have a very nice set of 67 2.0"S" pistons and cylinders.
This set has been measured, honed and the top ring was replace with new Geotze.
We also have a plethora of good used early pistons and cylinders.
Here is the spec sheet on the cylinders. The pistons show no measurable wear.
http://forums.pelicanparts.com/uploa...1232736534.jpg
