What to do? Broken 1970 2.0T Piston
Right side of the shortblock:
This is pretty much the condition of all:
But, this is where the kicker is. I have been EXCEEDINGLY careful and gentle throughout this entire disassembly process with the magnesium parts. I am unsnapping the circlips that hold the wristpins to the pistons and this "piece" falls out onto the garage floor. In the back of my mind, I think, "Oh *****!" but tell myself not to worry. I examine the piece, and instantly realize it's a broken piece of the #2 cylinder!
So, I'm now in panic mode.
Guys & gals, what are my options?
  • Where I could find another, single, stock 2.0T piston? 80 mm bore, 66 mm stroke?
  • Is JE Pistons a reasonable option (that is in my price range <$1K) ?
  • Stock 8.6:1, but what piston set could will yield a slightly higher compression?
  • I understand that 2.2L pistons share the same crank, and the 2.0 heads need to be matched. How do they do this?
I do NOT want to switch to 2.2L heads though. I am aiming for near stock, and a stock cam.
Thanks Pelicans in advance for your help,
Pete
Old 01-22-2009, 10:53 PM
I have a NOS and used 2.0T pistons.
I can also supply a set of used, in-spec, OEM 2.0E or 2.0 normal pistons if you'd like to raise compression.
PM me with your email for pics and prices.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-23-2009, 03:56 AM
Plavan's Avatar
I think I have a used set of 2.2L pistons. They came out of a motor that lost a valve spring. I'll sell you all 6 for $50 + shipping. (I have to make sure they are 2.2L pistons first- and they are still in the garage.)
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 01-23-2009, 08:29 AM
Try not, Do or Do not
Henry Schmidt's Avatar
If you are interested we have a very nice set of 67 2.0"S" pistons and cylinders.
This set has been measured, honed and the top ring was replace with new Geotze.
We also have a plethora of good used early pistons and cylinders.
Here is the spec sheet on the cylinders. The pistons show no measurable wear.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-23-2009, 10:51 AM
