HKZ Bob's Avatar
Is it Ok to buy Motormeister Cams
Hello I am looking for an 911 S cam right side.
This is the part no that I am looking for.
Camshaft right side 901-105-168-00
I saw an offer from MM on his homepage.
Should I go for it. What is your opinion?
Here his pricing.
Porsche Camshafts available
Prices per Pair
S M.F.I. 911 Porsche $299.95
All camshafts above are from Factory Porsche cores
Regards Bob
Please let me know you opinion.
Old 01-23-2009, 11:09 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The problem is that if you regrind a cam to a higher spec I.E. E to S without welding you end up reducing the base circle of the cam which negatively effects the rocker geometry. You can also end up with very little adjusting screw for the nut to seat on.
MM is notorious for doing this. Years ago I tried explaining this to them and they through me out of their shop.
If you're not willing to listen you aren't willing to learn.
Call John a DR Camshafts http://www.drcamshafts.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-23-2009, 11:26 AM
HKZ Bob's Avatar
Is it Ok to go with a cam from German Imported Parts.
Who made experience with them.
Regards Bob
Last edited by HKZ Bob; 01-23-2009 at 11:25 PM.. Reason: Sam man argument is also correct.
Old 01-23-2009, 11:44 AM
resident samsquamch
sand_man's Avatar
^^^what he said^^^
-jeff
Old 01-23-2009, 01:13 PM
resident samsquamch
sand_man's Avatar
In addition, I think you should take down the picture in post number 3, as I'm sure they are competitors of Pelican...
-jeff
Old 01-23-2009, 01:16 PM
I've seen a bunch of MM cams that were ground well below the base circle, just as Henry said. This left the rocker adjusting screw virtually bottomed and no ability to adjust the valves.
This is why I either buy new billets or have them reground by a reputable cam manufacturer thats familiar with these engines. Its not a place to cut $$$ corners.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-23-2009, 04:36 PM
HKZ Bob's Avatar
Sand-man,
Pelican replacement part no is 901-105-168-01.
About $1400.
Is is not fair to ask to forum opinion about price difference of $1000.
I am not advertising,
I would like to know if the $400 cam is a OEM part of a cheap repro.
B-quality etc.
Brand Reinshagen!
Bob
Old 01-23-2009, 11:19 PM
HKZ Bob's Avatar
Sand_man,
this is better now!
bob
Old 01-23-2009, 11:27 PM
resident samsquamch
sand_man's Avatar
Originally Posted by HKZ Bob View Post
Sand_man,
this is better now!
bob
Yes. It just looked weird being able to see their contact info posted on a site that charges you nothing for so much.
And as another reference point - though our engines are different - I paid $690.00 (pair) for the SC cams that went into my 930 engine a few years ago. I bought them from Imagine Auto. They took my old ones as a core/exchange. I'm not sure where Imagine souces them.
-jeff
Old 01-24-2009, 04:44 AM
Laneco's Avatar
When we first started out with Porsches, we inadvertently tangled up with MM... Never understood why we had such valve adjustment issues with that engine. We adjusted the valves six times in 2,500 miles (three times by a professional shop because we assumed that the problem was US...). When we had that engine autopsied at 2,500 miles, the gentleman who did the work explained that not only were the cams out of spec, they were also out of spec in a different way, left to right...
Thank you for the explanation, Henry.
angela
Hello
Old 01-25-2009, 09:30 AM
Still Doin Time
asphaltgambler's Avatar
I would not a buy a coffee cup from them used OR rebuilt. If I did it would leak or be the wrong size
Old 01-29-2009, 01:00 PM
