Engine identification help!
I'm looking to verify my spare engine with no serial number.
case # is 901.101.101 7R
6 bolt flywheel
I pulled it from a 76s but it has no serial numbers. Mag case, carrera tensioners, 11 blade fan, no thermal reactors on the exhaust.
I believe this to be a 2.7s possibly could be a warranty factory/dealer rebuilt or replacement engine???
Could any experts verify this or shed some light
Old 02-02-2009, 10:53 PM
In the mid 70s there was quite a few replacement cases. They were used because engine leakage from porus cases below the oil pump.
Bruce
Old 02-03-2009, 02:40 AM
Bruce,
Do you know if there exists a list of cases used in 911's?
I'm just taking apart my 73T MFI engine, and see the number in the casting as well as a casting manufacturers logo.
I would like to know if there is any information available that details the cases / manufacturers and modifications made over the range.
Thanks,
John
Old 11-29-2009, 05:10 PM
All the different "R"" ratings on the side of the block from 3R up to 7R have different reinforcements built in to the strength of the case.
Bruce
Old 11-29-2009, 06:44 PM
Thanks Bruce,
Mine is a 4R.
Any additional info would be appreciated !
John
Old 11-30-2009, 12:13 AM
