-   -   EFI for 82 3.0 SC (http://forums.pelicanparts.com/911-engine-rebuilding-forum/455857-efi-82-3-0-sc.html)
SchnellSchweitz 02-07-2009 07:53 AM
EFI for 82 3.0 SC
Hi gang,
I'm new here. Just purchased an '82 Targa. Can't believe I own a "Porsche!"
My friends are soooo jealous...
Anyway, I'm in the middle of my engine rebuild and I'm considering replacing the CSI with an EFI from Blitz. I've seen some older posts on this, but curious if there are any more folks to offer input on this conversion.
I also would like to know what the total conversion is costing these days. I see the parts go for around $1700 total. But are there other parts I will need.. such as a new air box or other stuff?
lucittm 02-07-2009 09:11 AM
How well did your '82 run with the stock CIS? The money part of the EFI conversion is the easy part. You will spend a good percentage of your life on earth getting it dialed in. But then it will all seem worth it.
Mark
175mph951 02-07-2009 11:37 AM
go with a megasquirt kit like from bitz racing....trouble free easy install and once its dialed in you never need to mess with it again....turn the key and starts and idles on first crank every time....plus throttle response and fuel economy is much better....
the megasquirt efi isnt at all bad to dial in...it actually has an autotune function that helps you get a good baseline to start with.
Supi 02-07-2009 12:36 PM
What is actually the impact to fuel economy ? I am having a kit from Bitzracing waiting the installation ? 10% down or more ?
Sami
175mph951 02-07-2009 12:52 PM
Supi:
ive never calculated it but i did feel that i was gasing up less....the injectors are only opening once or twice per ignition cycle....not continuous as in CIS...definitaly makes a difference...youll be very pleased with the kit
SchnellSchweitz 02-08-2009 08:32 AM
Thanks for the replies....
It sounds like there are pros and cons to it... but overall it is probably the right thing to do for me.
My Targa came with an inoperable engine... I have never turned the key on it so I have can't reference my previous "CIS" experience. To me, the CIS system looks cumbersome and antiquated. I'm sure I will draw some abuse for saying this... I am an admitted rookie here. I like the idea of a more simple fuel delivery system.
Does anybody know if the EFI system eliminates the accumulator and fuel filter? Does this conversion require a new air system? If so, any recommended products?
Thanks again for your input... positive and negative.
kenikh 02-08-2009 02:40 PM
There is really no downside - it is simpler. Tuning takes some time, but as long as you can handle a lptop it is simple enough. You can keep using the stock airbox if you like and I prefer the stock look actually. It gets rid of all of the other weird bits like Warm up Regulator and fuel distributor since you are shooting fuel from a rail directly into the runners. I say do it - if your CIS is a disaster, it willa ctually be cheaper to do the Bitz kit than fix the CIS. And to be clear, you should expect BETTER, not worse fuel economy.
pete-stevers 02-09-2009 10:20 PM
What is a link to the blitz kits, or their web site
Won 02-09-2009 11:04 PM
http://www.bitzracing.com/
JohnJL 02-10-2009 12:19 AM
You are going to need a new intake, usually a Carrera or an ITB kit. I've done it with Megasquirt and then replaced with Adaptronic. Its not that hard, but does take some tuning. Once its set though you're good to go.
The Bitz instruction manual is complete and illustrated. You leave your pump, accumulator and a (replacement recommended!) stock filter.
Spring for a knock sensor "while you're in there." Megasquirt can handle that.
roberthornn 02-10-2009 05:47 PM
thanks
thanks for the info!
175mph951 02-10-2009 07:10 PM
you dont need a new intake....bitz sells pieces and shows how to convert a cis manifold, done it on 4 different cars works perfect
sc_rufctr 02-10-2009 11:06 PM
I'm considering this for my own car.
I have a 1978 SC and it runs good but if any part of the CIS fails it would be hundreds of dollars at the least.
For instance a new fuel distributor would be about $1000 (Aussie Dollars)
My ideal set-up would be the PMO ITBs with the "Bitz racing" Megasquirt kit.
I'm guessing it would pay for itself in the long run with the better fuel consumption and more horse power.
Spend some time at the web site. You can sign up in the Yahoo group as well. Lots of good information... :cool:
http://www.bitzracing.com/index.html
http://autos.groups.yahoo.com/group/bitzracing/
Aurel 02-11-2009 07:33 AM
This thread brings a question: once you have done a CIS to EFI conversion, can you go with more agressive cam profile than 964, or is it really the dome shaped of the CIS pistons (and not the CIS induction itself) that limits the cam you can use?
kenikh 02-11-2009 09:07 AM
Possibly, but still run into the "common plenum" reversion issues. It takes ITBs to really get aggressive, since they block reversion low in the intake tract.
euro911sc 02-11-2009 10:18 AM
IRRC, the domes in the CIS pistons are not very thick and cutting valve pockets, while it can be done, is tricky. So your max lift is limited. With out the CIS you get rid of the overlap pulse issue so you could increse the overlap.
You could certainly replace them :) Then you could go radical ... but that is $$s
-Michael
sjf911 02-11-2009 11:07 AM
That was my impression the first time I got a chance to look at the CIS in depth. The Bitz kit looks like a great way to EFI without having to reinvent the wheel and do a lot of changes to your engine. OTOH, EFI conversion opens an enormous door for changes including electronic distributor-less ignition and future performance enhancements. There can be a significant time investment in getting your tuning correct for which a wide-band O2 exhaust sensor is a necessity.
I am running my EFI without an accumulator but with a stock fuel filter (Carrera 3.2 setup).
911Mac 02-15-2009 12:19 PM
Lots of good info here, but you need to understand that there are many variations possible when converting your car to Megasquirt EFI. You can use the Tbitz kit or design your own system which is much more involved.
You can read all about Megasquirt here: http://www.bgsoflex.com/megasquirt.html
There are two different controllers, MSI and MSII. There are also different versions of code that can be loaded that add various functions. For example, the MSI standard code doesn't support EDIS, but you can load a version that adds that.
The Tbitz kit is designed to use the original intake runners, airbox, and throttle body. It uses the MSI v3 controller with custom code that eliminates the need for a TPS (throttle position sensor). So if you want to load a different version of the code later, you'll have to add a TPS. Not that big of a deal, really depends on your throttle body. But if all you're looking for is a good solid EFI, then there's no need to change anything.
I've been running a Tbitz kit for 4 or 5 years on my daily driver, an 82SC. I see a 2 to 3 MPG increase over the CIS (mostly highway driving). I added a wideband O2 sensor early on which lets me set the target AFR a bit richer for better performance. I have had no problems, starts easily hot or cold every time.
Your engine isn't currently running, if it has other issues you're not aware of it could make an EFI conversion much more difficult. You should also be aware that once you've done the conversion, the local Porsche garage won't be much help resolving problems related to the EFI.
If you still want to go the Tbitz route, download the installation manual from their web site. It explains everything about installing the kit. It can be done with the engine in the car or with an engine drop.
flat6pilot 02-15-2009 09:08 PM
Bitz
Just finished a TBitz Racing EFI conversion myself: (1980 ROW SC, European Racing Headers, M&K 2 in 2 out muff, MSD Ignition)
<br><br>
http://forums.pelicanparts.com/uploa...1234760780.jpg
http://forums.pelicanparts.com/uploa...1234760804.jpg
SchnellSchweitz 02-19-2009 07:47 PM
Wow.... can you share what your costs were?
That's a really nice look! :-)
SchnellSchweitz 02-23-2009 05:04 PM
Also
Does any body know what intakes will fit an '82 3.0L for the EFI conversion?
3.2
3.3
sc_rufctr 02-24-2009 03:10 AM
I've seen it done with a 3.2 manifold but he was using the SDS standalone EFI.
http://www.sdsefi.com/
sc_rufctr 02-24-2009 03:14 AM
Check out the Project Page... There's a few 911s...
http://www.sdsefi.com/project.html
sjf911 02-24-2009 08:42 PM
The 3.2 manifold fits but it is not a perfect fit. The intake ports on the 3.0 heads are shaped to fit the CIS injectors while the ports on the 3.2 are shaped to fit the electronic injectors. Most people hog out the port on the 3.0 heads to fit the 3.2 manifold. I elected to just swap out to 3.2 heads for a perfect match. Also, I used megasquirt (MS-II) similar to the Tbitz setup.
http://forums.pelicanparts.com/uploa...1235536805.jpg
JohnJL 02-24-2009 10:48 PM
The alu 3.2 intake on 3.0 heads leaves a narrow manifold face on one side. Using teh 3.2 insulator blocks helps but it is still narrow.
flat6pilot 03-01-2009 10:21 PM
TBITZ KIT: $1400
INJECTORS: $200
FUEL PRESS REGULATOR: $100
WIDE BAND O2 SENSOR: $200
TOTAL COST: $1900
I'd recommend the WBO2 sensor. Although it's not necassary as Tony includes a narrow band sensor w/ the kit.
I should be ready to fire it up in about 2 weeks. :D
