Cam tower plug, spray bar
I'm trying to pull the cam tower spray bar plugs. I have one drilled and tapped for a 6mm bolt. Using large washers on the bottom and smaller ones on top I have the 6mm bolt through the washers and screwed into the threaded hole then tightened down a nut on the bolt to the washers. Tightening the nut the plug doesn't seem to want to move, should I use heat? I'm being careful here so I don't strip the thread I've made.
Old 02-15-2009, 03:51 PM
plug
Thats the method I use, some are tough, but never had to use heat though, has it pulled the tapped threads? if not keep pulling
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 02-15-2009, 04:33 PM
nreed's Avatar
I had mine machined out.
Norm '86 930
AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL
HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear)
Old 02-15-2009, 04:47 PM
Well I moved on to the next tower and it came right out, although the plug left some burs and the spray bar was a sob to get out, plus put a real nice scrape mark on the spray bar. I will apply more pressure to the first towers plug. I see the host is showing the spray bar as NLA.
Old 02-15-2009, 06:04 PM
Got the first towers plug out, and I have another tower thats a bit biffed up so I scavenged a spray bar from it.
I see from searching that some are using 1/8" threaded pipe plug instead of the factory press fit plug. Any down side to this?
Old 02-15-2009, 08:59 PM
spray bars
They are available, contact me and I will give you a Porsche #
Old 02-16-2009, 03:15 AM
Air Medal or two
afterburn 549's Avatar
Note...I piped taped the plug ends and of course inserted pipe plugs........next time Pc of cake
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-16-2009, 03:42 PM
