What are these connectors for?
Engine is a 76 2.7. What are these connectors for?
http://forums.pelicanparts.com/uploa...1235360258.jpg http://forums.pelicanparts.com/uploa...1235360277.jpg |
first one is power to blower fan high on top of the #3 runner
2nd pic is connector for vacuum pod sitting under the blower fan in previous pic controls a vacuum to the warm up regulator on the SC, Ii is called a thermal valve Bruce |
Thanks Bruce. Here's a pic of the engine. I assume the blower fan sits on the pedestal that's bolted to the intake runners? Also, is the "vacuum pod" missing as well? FYI - this engine is going into a 914/6 conversion so I assume I don't need the blower fan since I won't be using the stock HE's.
http://forums.pelicanparts.com/uploa...1235418834.jpg |
In the pic, dropping down off the fan support the thin metal flat is the support for the vacuum pod
914 wont need it Bruce |
| All times are GMT -8. The time now is 06:13 PM. |
