Santa Clarita, Ca.
Engine is a 76 2.7. What are these connectors for?
first one is power to blower fan high on top of the #3 runner
2nd pic is connector for vacuum pod sitting under the blower fan in previous pic controls a vacuum to the warm up regulator on the SC, Ii is called a thermal valve Bruce |
Santa Clarita, Ca.
Thanks Bruce. Here's a pic of the engine. I assume the blower fan sits on the pedestal that's bolted to the intake runners? Also, is the "vacuum pod" missing as well? FYI - this engine is going into a 914/6 conversion so I assume I don't need the blower fan since I won't be using the stock HE's.
In the pic, dropping down off the fan support the thin metal flat is the support for the vacuum pod
914 wont need it Bruce |
