Santa Clarita, Ca.
Arrow Oil return tube orientation
Yes, I know I'd be better off with the solid tubes but this is what I have. But, does it matter which way these go on?
Old 03-14-2009, 08:18 AM
abit off center
cgarr's Avatar
I always try to set them up so the flow is away from the overlap not into it. But since the tubes will fill up with oil anyhow when not running it may not matter.
______________________
Craig
G2Performance
Old 03-14-2009, 08:35 AM
Santa Clarita, Ca.
Yeah, that's what I was thinking too. If that's the case, these look to be put on backwards.
Old 03-14-2009, 09:02 AM
3.2 CAB's Avatar
+1 on being reversed. Also, I have not seen many of the spring loaded return tubes.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-14-2009, 03:37 PM
The spring loaded, the only ones I had ever seen, were onmy 76 turbo when I bought it in 92
Old 03-14-2009, 07:00 PM
It doesn't matter which way they go. If they don't leak don't f... with them.
-Andy
Old 03-16-2009, 07:55 PM
