930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
Labor time?
Whats a good labor for oil return tubes , the one that expand ?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 03-06-2009, 04:48 PM
Free minder
Aurel's Avatar
101 projects, p.76 says 1-2h per side. That is DIY. A pro should be able to both sides in less than 2h. IMHO. I did it, long time ago, cannot remember how long it took me (and I am not a pro anyways...).
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 03-06-2009, 05:47 PM
h20cooled7's Avatar
to charge a customer on a side job.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 03-07-2009, 04:53 AM
3 restos WIP = psycho
kenikh's Avatar
If you use expandables as the replacement (you should if not rebuilding), this shouldn't take any competent mechanic more than 1 hour shop time (usually the charge minimum). If getting quoted for more, walk.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-07-2009, 06:19 AM
Chain fence eating turbo
Why would this take 4 hours?
I would think about 10-15 minutes. Half of that would be getting the car jacked up or on a lift.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 03-07-2009, 11:04 AM
safe's Avatar
It depends on the car, what HEs on it and if it has air injection in exhaust ports.
Magnus
Old 03-07-2009, 01:01 PM
Super Moderator
cstreit's Avatar
Remember there's an oil-change on this too. ... and often a fair bit of cleaning (hence replacing the tubes). Two hours is fair. ...and with the HE's on some of these can be a REAL bear
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-07-2009, 03:26 PM
Oh yeah, I forgot I have no heat and turbo headers.
Old 03-08-2009, 02:56 PM
For sure, god forbid that the shop that invested thousands in tools and equipment make any type of return. Just working on Porsche's should be an honor that is done for free
Old 03-15-2009, 02:16 PM
Air Medal or two
afterburn 549's Avatar
Lets see some exhaust systems are in the way..are they not ?
valve adj too..
Oil change ...
yup 1/2 hour LOL
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 03-15-2009, 02:32 PM
Funny you say that, I do work on Porsches for free. Learn to read further down the post first before you pop off.
Old 03-15-2009, 08:13 PM
Air Medal or two
10 to 15 minutes ?
A- put car in air
1- drain oill
2--remove any exhaust in the way
3- - remove the 12 old tubes
4--install 12 new tubes
5-install exhaust
6-fill up oil
B- dwn off lift
7 test drive , check for leaks
8- do the paper work
9 - yea 15 minutes
A man has got to know his limitations......... LOL
Old 03-15-2009, 09:48 PM
Labor
Remember to factor in rusty/frozen & broken exhaust studs as well.
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-16-2009, 09:54 AM
Air Medal or two
Yes for got those,. add an other 30 seconds ..... LOL
Old 03-16-2009, 10:01 AM
Is that the famous "flat 18" that has 12 oil return tubes? Just asking.....
-Andy
Old 03-16-2009, 07:50 PM
Originally Posted by afterburn 549 View Post
2--remove any exhaust in the way Not mine
3- - remove the 12 old tubes I cant find the other 8
4--install 12 new tubes Still looking
7 test drive , check for leaks Why? Just start it.
Old 03-16-2009, 09:12 PM
Air Medal or two
My mistake ...I make them
Old 03-17-2009, 09:47 AM
