Labor time?
Whats a good labor for oil return tubes , the one that expand ?
101 projects, p.76 says 1-2h per side. That is DIY. A pro should be able to both sides in less than 2h. IMHO. I did it, long time ago, cannot remember how long it took me (and I am not a pro anyways...).
to charge a customer on a side job.
If you use expandables as the replacement (you should if not rebuilding), this shouldn't take any competent mechanic more than 1 hour shop time (usually the charge minimum). If getting quoted for more, walk.
Why would this take 4 hours?
I would think about 10-15 minutes. Half of that would be getting the car jacked up or on a lift. |
It depends on the car, what HEs on it and if it has air injection in exhaust ports.
Remember there's an oil-change on this too. ... and often a fair bit of cleaning (hence replacing the tubes). Two hours is fair. ...and with the HE's on some of these can be a REAL bear
Lets see some exhaust systems are in the way..are they not ?
valve adj too.. Oil change ... yup 1/2 hour LOL |
A- put car in air 1- drain oill 2--remove any exhaust in the way 3- - remove the 12 old tubes 4--install 12 new tubes 5-install exhaust 6-fill up oil B- dwn off lift 7 test drive , check for leaks 8- do the paper work 9 - yea 15 minutes A man has got to know his limitations......... LOL http://forums.pelicanparts.com/suppo...leys/roker.gif |
Labor
Remember to factor in rusty/frozen & broken exhaust studs as well.
Mike |
Yes for got those,. add an other 30 seconds ..... LOL
Is that the famous "flat 18" that has 12 oil return tubes? Just asking.....
-Andy |
My mistake ...I make them
| All times are GMT -8. The time now is 11:39 AM. |
