930s rule the wasteland
Labor time?
Whats a good labor for oil return tubes , the one that expand ?
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Free minder
101 projects, p.76 says 1-2h per side. That is DIY. A pro should be able to both sides in less than 2h. IMHO. I did it, long time ago, cannot remember how long it took me (and I am not a pro anyways...).
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
to charge a customer on a side job.
3 restos WIP = psycho
If you use expandables as the replacement (you should if not rebuilding), this shouldn't take any competent mechanic more than 1 hour shop time (usually the charge minimum). If getting quoted for more, walk.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Chain fence eating turbo
Why would this take 4 hours?
I would think about 10-15 minutes. Half of that would be getting the car jacked up or on a lift.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
It depends on the car, what HEs on it and if it has air injection in exhaust ports.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Super Moderator
Remember there's an oil-change on this too. ... and often a fair bit of cleaning (hence replacing the tubes). Two hours is fair. ...and with the HE's on some of these can be a REAL bear
Air Medal or two
Lets see some exhaust systems are in the way..are they not ?
valve adj too.. Oil change ... yup 1/2 hour LOL
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Funny you say that, I do work on Porsches for free. Learn to read further down the post first before you pop off.
Air Medal or two
A- put car in air 1- drain oill 2--remove any exhaust in the way 3- - remove the 12 old tubes 4--install 12 new tubes 5-install exhaust 6-fill up oil B- dwn off lift 7 test drive , check for leaks 8- do the paper work 9 - yea 15 minutes A man has got to know his limitations......... LOL
Labor
Remember to factor in rusty/frozen & broken exhaust studs as well.
Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Air Medal or two
Yes for got those,. add an other 30 seconds ..... LOL
Is that the famous "flat 18" that has 12 oil return tubes? Just asking.....
-Andy
72 Carrera RS replica, Spec 911 racer |
Air Medal or two
My mistake ...I make them
