Eye of the Toiger
matty74's Avatar
Do I go 12.5:1 or 11.5:1 CR je pistons??
I'm planning a rebuild of my 3.6 for my 911 hot rod project, I am going to run RSR cams and 50mm PMO's.
I need to purchase a set of JE pistons and I'm not sure if what CR to go for.
What are the davantage/disadvantage with the different CR?
What kind of HP could I expect from this set up?
I'm going to use this for the Street as well as some track days so I want the best of both worlds.
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 03-09-2009, 11:30 PM
Street use???
11.5:1 for sure,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-10-2009, 10:15 AM
And twin plug I assume
Robert
Currently Porsche less (but the wife has 2)
Old 03-12-2009, 02:33 PM
Eye of the Toiger
matty74's Avatar
absolutley
Old 03-12-2009, 02:43 PM
3 restos WIP = psycho
kenikh's Avatar
You'd better get big enough cams to ensure that dynamic compression is low enough, unless of course you are integrating engine management w/ knock sensing. The only reason the factory 3.6s used such high CR on the 3.6 was due to the electronic gadgetry that could adjust ignition timing on the fly. If not, you'd better plan on GE80 or bigger.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-13-2009, 09:10 AM
Eye of the Toiger
matty74's Avatar
I'm going RSR grind with 50mm PMO's
Old 03-13-2009, 01:00 PM
If going with carbs, you might want to add in a J&S Safeguard for independent cylinder knock sensing and control if you plan on running 11.5:1 still unless you plan on running race gas all the time.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-13-2009, 01:40 PM
Eye of the Toiger
matty74's Avatar
I will be running it on 98 Octiane which is the highest quality one can get i n Australia.
Old 03-13-2009, 02:27 PM
kenikh's Avatar
98 octane (Australia uses the RON calculation) won't cut it without knock protection. 98 RON is just below 91 Octane US (ROM+MON/2). You'd be well served to consider dialing your CR back by ~1.5 points, even with twin plugs on those big pistons.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-13-2009, 02:33 PM
Eye of the Toiger
matty74's Avatar
I'll talk to my mechanic today, I'm doing a ground up build so I guess it's a good idea to the Knock protection. Is there a website with info on this product?
Old 03-13-2009, 02:42 PM
http://www.jandssafeguard.com/
Charles Navarro
Old 03-14-2009, 06:44 AM
