-   -   What's so special about a 7R case? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/462085-whats-so-special-about-7r-case.html)
ahdoman 03-10-2009 06:00 PM
I've got a 2.4CIS that is a 7R case (73.5). Why is the 7R case so desirable? If I'm running CIS does it really matter what case I have/use?
Steve@Rennsport 03-10-2009 06:07 PM
The 7R case contained stiffening ribs and thicker walls (in some areas) than its predecessors.
These changes made the 7R a better candidate for larger-displacement, high RPM engines.
jbell959 03-11-2009 11:52 PM
The 73.5 7R case is special because it has all the benefits of the stronger 7R case like Steve said but it also has the smaller spigots for the cylinders. In 74 they went to the 90mm pistons and opened up the spigots. So anyone that wants the stronger 7R case to build a 2.2 or 2.4 engine would want your case.
kenikh 03-13-2009 09:12 AM
Yep - matter of fact Steve just did my small spigot 7R for a 2.3L ST motor I am building. This case was the best choice bassed on weight and the fact it has accomodation for an MFI pump (the early aluminum case doesn't - and it is heavier).
trekkor 03-16-2009 10:29 PM
That's the same case my 2.6 is built on.
Just running it for the first time this week.
KT
tom1394racing 03-17-2009 02:57 AM
Here's some pics showing the differences in the case structure between a 7R and an early mag case.
Note the extra reinforcing ribs in the 7R.
7R
http://forums.pelicanparts.com/uploa...1237283387.jpg
http://forums.pelicanparts.com/uploa...1237283447.jpg
Early Mag Case
http://forums.pelicanparts.com/uploa...1237283555.jpg
http://forums.pelicanparts.com/uploa...1237283598.jpg
gestalt1 03-17-2009 05:09 AM
is there a way to reduce the spigot diameter on a 74-77 7r case? i would think a sleeve would work. there is a set of 86.7mm st cylinders on ebay that require an odd size spigot - it would be a good use of a later 7r case i would think.
kenikh 03-17-2009 08:28 AM
Yes - Supertec offers a kit for this. It involves spacers, aerospace adhesive and some special sauce.
rswannabe 03-17-2009 05:53 PM
The other benefit of a 2.4 7R case like yours is it came off a car that did not have thermal reactors. Most of the later 7R cases used for the 2.7 liter mid year motors had thermal reactor in the exhaust, which led to higher motor operating temperatures, and more sever heat cycles for the case. This leads to faster wear and fatigue for the magnesium.
Or so I have been told.....
914/6 03-17-2009 06:51 PM
4/5R is real close also, just missing the lower vertical gussets.
