Santa Clarita, Ca.
Question What's so special about a 7R case?
I've got a 2.4CIS that is a 7R case (73.5). Why is the 7R case so desirable? If I'm running CIS does it really matter what case I have/use?
Old 03-10-2009, 06:00 PM
The 7R case contained stiffening ribs and thicker walls (in some areas) than its predecessors.
These changes made the 7R a better candidate for larger-displacement, high RPM engines.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-10-2009, 06:07 PM
The 73.5 7R case is special because it has all the benefits of the stronger 7R case like Steve said but it also has the smaller spigots for the cylinders. In 74 they went to the 90mm pistons and opened up the spigots. So anyone that wants the stronger 7R case to build a 2.2 or 2.4 engine would want your case.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 03-11-2009, 11:52 PM
3 restos WIP = psycho
kenikh's Avatar
Yep - matter of fact Steve just did my small spigot 7R for a 2.3L ST motor I am building. This case was the best choice bassed on weight and the fact it has accomodation for an MFI pump (the early aluminum case doesn't - and it is heavier).
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-13-2009, 09:12 AM
JW Apostate
trekkor's Avatar
That's the same case my 2.6 is built on.
Just running it for the first time this week.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-16-2009, 10:29 PM
Here's some pics showing the differences in the case structure between a 7R and an early mag case.
Note the extra reinforcing ribs in the 7R.
7R
Early Mag Case
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 03-17-2009, 02:57 AM
gestalt1's Avatar
is there a way to reduce the spigot diameter on a 74-77 7r case? i would think a sleeve would work. there is a set of 86.7mm st cylinders on ebay that require an odd size spigot - it would be a good use of a later 7r case i would think.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 03-17-2009, 05:09 AM
kenikh's Avatar
Yes - Supertec offers a kit for this. It involves spacers, aerospace adhesive and some special sauce.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-17-2009, 08:28 AM
The other benefit of a 2.4 7R case like yours is it came off a car that did not have thermal reactors. Most of the later 7R cases used for the 2.7 liter mid year motors had thermal reactor in the exhaust, which led to higher motor operating temperatures, and more sever heat cycles for the case. This leads to faster wear and fatigue for the magnesium.
Or so I have been told.....
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 03-17-2009, 05:53 PM
4/5R is real close also, just missing the lower vertical gussets.
Old 03-17-2009, 06:51 PM
