B D B D is offline
B D's Avatar
Which Washer for Case Nut by Timing Chain?
What washer should I use for the hidden 15mm case nut located near the left timing chain? I was thinking nylock nut with a aluminum crush washer.
68 911L
Old 04-15-2009, 10:30 PM
inside, youre talking a 17mm and I would not use aluminum or nyloc inside the engine.
Bruce
Old 04-16-2009, 05:13 AM
B D B D is offline
B D's Avatar
So what is the correct setup then?
68 911L
Old 04-16-2009, 08:06 AM
17mm nut and a wavey washer.
Bruce
Old 04-16-2009, 07:18 PM
