Bearing removal
Anybody have a safe trick for removing a stubborn nose bearing?
Thanks in advance.
When you have the crank in your hand, the nose bearing comes right off. With the case together, it sits on a retainer pin so you cant remove it
Bruce |
My nose bearing is stuck on...
I can't seem to pry mine off with my hands... I wonder if it jammed onto the retainer and stuck?
What would you suggest using to pry it off. Perhaps a flathead SD and a rubber mallet and pound from the outside edge of the bearing??? ![]() Thanks for your help...
Just tap it with a SD on the lip below your arrow. Tap upwards toward center. Tap REALLLLLY gently to get it to move.
Cheers, Matt |
Take a flat head screw driver and place the tip between the case and the lip of the bearing. Turn the screw driver by hand and the bearing will move off it's seat.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Your picture with the RED arrow is showing us the #1 main bearing not the #8 nose bearing?
Mark Jung Bend, OR MFI Werks.com |
