SchnellSchweitz's Avatar
Bearing removal
Anybody have a safe trick for removing a stubborn nose bearing?
Thanks in advance.
Old 04-04-2009, 02:52 PM
When you have the crank in your hand, the nose bearing comes right off. With the case together, it sits on a retainer pin so you cant remove it
Bruce
Old 04-04-2009, 07:13 PM
My nose bearing is stuck on...
I can't seem to pry mine off with my hands... I wonder if it jammed onto the retainer and stuck?
What would you suggest using to pry it off. Perhaps a flathead SD and a rubber mallet and pound from the outside edge of the bearing???
Thanks for your help...
Old 04-05-2009, 09:57 AM
Just tap it with a SD on the lip below your arrow. Tap upwards toward center. Tap REALLLLLY gently to get it to move.
Cheers,
Matt
Old 04-05-2009, 04:31 PM
Take a flat head screw driver and place the tip between the case and the lip of the bearing. Turn the screw driver by hand and the bearing will move off it's seat.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-05-2009, 06:17 PM
356RS's Avatar
Your picture with the RED arrow is showing us the #1 main bearing not the #8 nose bearing?
Mark Jung
Bend, OR
MFI Werks.com
Old 04-06-2009, 08:01 AM
