67targa's Avatar
Send a message via Yahoo to 67targa
A targa looking for her engine
Does anyone out there have a list of vin#/engine # combinations. I have 500404 which came with a 69t implant. I now have an almost completed restoration with no heart,,,,,,help my tangerine mistress please.
67' tangerine targa
Old 04-10-2009, 11:07 PM
djpateman's Avatar
To get the engine # for a VIN you MUST get the COA from PCNA.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-11-2009, 07:59 AM
67targa's Avatar
Yeah, I was told this. While on early S, one member had built a list of vins with their corresponding engine and trans #'s. I thought I would take a chance.
I found 909018 in good condition long block form minus the cylinders for a good price. Off to Henry at Supertec, well after I work some overtime. Its is heart wrenching to see her in the garage without an engine. I am buying Wayne's engine book today to start my homework. I am sure I will be posting questions once I scour the archives and formulate my game plan. So, thanks for all your patience in advance!
Long live the long hood!!
67' tangerine targa
Old 04-11-2009, 10:00 AM
djpateman's Avatar
Yes, that might well be myself with the list, however if you want to know the exact engine that came in the car you will need the COA. Engine #'s bounce around a lot compared to the VIN. If you don't have an S then you would be looking for a serial number like 911684 or higher. If you have 909018 available, then please let me know the build # stamped next to the type # 901/05. If you have a bare case, please tell me the 'matching' numbers on the case halves that indicate they are a paired set.
Addicted since 1975
Old 04-11-2009, 05:37 PM
67targa's Avatar
Thank you for your reply. I saw a thread Grady the listed my # as a 901/05 webers with solex cams, a late 66 build. I found some #s, for the case 901.101.101.01, 901.101.102.01 and on the cam towers 901.105.111.OR
Where would I find 901/05 on the case or is this a reference only
THanks Scott
67' tangerine targa
Old 04-12-2009, 12:29 AM
304065's Avatar
A 67 normal has a 901/06 engine.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-12-2009, 10:56 AM
67targa's Avatar
You are right, my car had no engine and I found the 901/05 the other day. Is there a 901/05 listing on the case anywhere? So much dirt etc. I can not see it
67' tangerine targa
Old 04-12-2009, 01:19 PM
djpateman's Avatar
Yes, see this thread:
http://www.early911sregistry.org/forum/showthread.php?t=24913
Please list the three numbers you find.
Addicted since 1975
Old 04-13-2009, 02:09 PM
67targa's Avatar
the # on the front right side of the alternator support is 909018
Thanks for the link
67' tangerine targa
Old 04-13-2009, 09:17 PM
67targa's Avatar
Man this is dirty! I found the following after spaying degrease on it. I hope this is the answer to your question.901/5 5 017 is also on the block
Thank again for the link.
Scott
67' tangerine targa
Old 04-16-2009, 08:11 AM
djpateman's Avatar
If the engine is type 901/05 serial 909018 then the build # should be 5071. Please check again.
Photos might help; the German 7 & 1 can be easily comfused at times depending on the font.
On the top of the engine where the case halves are bolted together, there is a "pairing number" on each boss. Can you find it also?
Addicted since 1975
Old 04-17-2009, 07:21 AM
67targa's Avatar
You are correct it is 5071. I have been known to be a little dyslexic. The other numbers on top appear to be either 99 or 66. On one of these stampings there appears to be __ directly below. Does this help?
Scott
67' tangerine targa
Old 04-18-2009, 10:18 PM
djpateman's Avatar
Yes, Thanks very much.
Addicted since 1975
Old 04-19-2009, 07:46 PM
