Oil pressure sender
I just started a rebuild on my 3.0 and could not break the oil pressure sending unit free. When I put pressure on it with a wrench the square block it sits on came loose so I took that and the unit out as one piece. Any suggestion on how to seperate the sender?
Also, when I pulled the motor I goofed and did not note two things:
1) There was a vacuum line coming into the engine coompartment from the firewall near the crusie control module - it came loose during the drop and I don't know where it goes - does it go the side of the airbox - I noticed a nipple facing the 1-3 cylinder bank.
2) The wire on the harness that connects to the oil temp sender on the oil breather housing - it came loose during the disassembly and I did not notice it until I pulled the wiring harnesses out. Anyone know what color wire connects to this sender?
Thanks - these are probably pretty basic and dumb questions but rest assured, since I am just beginning the rebuild there will be more to come !
Old 10-17-2005, 11:06 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Place the block in a vise and put a wrench on the sender. It takes a very thin wrench as pictured.
I need more info (maybe a picture) to id the hose.
The wiring is as follows:
Green/ red = oil pressure
Green / black = oil temp
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-18-2005, 08:04 AM
Thanks Henry. The temp sender I was concerned with was the one on the oil breather housing. Any ideas on which wire connects? I am sure it will be the one left over that I did not make a note of but sinec it is a hard place to reach I just want to make sure I get it right the first time.
Old 10-18-2005, 12:44 PM
red901's Avatar
What is the wrench size (across the flat) to remove the oil pressure sender from a 1988 3.2 Carerra motor? I see the wrench in the photo, but when I bend a wrench, I want to bend the right size.
Thanks in advance, Tom
Old 05-05-2009, 02:03 PM
red901's Avatar
Oil Pressure Sender wrench size needed
See the previous post for details.
Thanks, Tom
Old 05-05-2009, 02:04 PM
You must be doing an 80 to 83 and the temp wire on the breather is part of the separate harness for the oxygen sensor lambda that connects to the chassis on the front of the engine, either a 6 or 12 wire coinnector depending on the year.
Old 05-05-2009, 04:04 PM
red901's Avatar
I am looking for the wrench size (across the flat) that I need for the sender.
Old 05-05-2009, 06:09 PM
I'm here to cause trouble
jimbauman's Avatar
It's 24mm...
Old 05-05-2009, 07:22 PM
red901's Avatar
Thanks, Jim
Old 05-06-2009, 05:45 AM
