VincentVega's Avatar
3.6 ARP Head Studs
Quick confirmation.
The manual calls for loctite 639 on the head stuts in the case. However the ARP doc's say use the special sauce, ARP assembly lubricant.
Is proper application ARP Assembly lube at the case and the bolt end?
Old 05-07-2009, 10:54 AM
Chris,
Use loctite only at the case end.
ARP assembly lube only on the head nut end.
Lyn
Track: 91 C2 SuperCup wannabe, 08 Cayman S
Street: 85 RUF BTR Slant-nose, 70 911 T Coupe Pastel Blue
Projects: 82 911 SC 3.6, 72 911 T Coupe, 74 914 Signal Orange
Old 05-10-2009, 06:59 PM
EBS_Don's Avatar
Hey there Chris!
Exactly; LocTite on case end, lube on nut end. Make sure to follow the directions on the back of the box for torque!
Don
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 05-13-2009, 09:39 AM
