-   -   Wayne's Top Picks - Cams for 2.7 High Compression (http://forums.pelicanparts.com/911-engine-rebuilding-forum/472027-waynes-top-picks-cams-2-7-high-compression.html)
gridgway 05-01-2009 04:57 AM
I am putting together a nice 2.7 MFI motor out of the remains of a rather nasty 2.7motor. This is to go in a 73 2.7RS recreation.
The plan is high compression with Mahle barrels and JE high domed pistons with standard S induction and a newly reconditioned MFI pump. The plan is to allow it to rev up to about 7500.
The question then is that the old cams are no use so I have to find some others. I don't want to lose mid-range urge, but am looking to have a good pull all the way up.
The car will be used for fast road and a few track days.
Any thoughts on what are suitable cams to give good pep at the top end?
Graham
DohertyCM 05-01-2009 05:28 AM
elgin cams
I would talk with Elgin Cams...I got what they called a DC-10 cut..I have no idea what that is...But when I was asking the same questions you were I kept getting sent there. Its a modification to the 964 cams, which is what I wanted.
BUT i have the CIS system. I would give them a call and ask what they have found works for your MFI set up.
But then again you have the guys here on this board....Ask and you shall receive.
Steve@Rennsport 05-01-2009 08:36 AM
Graham,
You will need to know your precise compression ratio before choosing a camshaft, especially if you are using pump gas on single-ignition,... :)
Further, MFI pumps are matched to the camshaft profiles and I would not stray too far from factory cams to prevent running problems.
jluetjen 05-01-2009 11:19 AM
Here's my $0.02 from a couple of years ago.
