-   -   Scraping sound (http://forums.pelicanparts.com/911-engine-rebuilding-forum/472879-scraping-sound.html)
Inter911 05-05-2009 02:33 PM
Scraping sound
I've got a very light scraping sound coming from the flywheel area on my engine when I turn it over by hand. The engine in a 2.4S and its mating to a 901 trans. I put on a Fidenza lightened flywheel, a ring gear from Kennedy Engineering to adapt it to the 901 and then a Stage 1 clutch assembly also from Kennedy. The noise is not every revolution but rather seems every 1/4 or 1/6 of a turn. Along with the noise is a very light amount of resistance. Any thoughts?
Steve@Rennsport 05-05-2009 03:14 PM
Sounds like either your flywheel is rubbing the case (not abnormal for Fidanza's) or the pressure plate bolts are doing the same,...... :)
Inter911 05-05-2009 03:47 PM
My thoughts too. Now I have to order new flywheel bolts yet again and take it apart to see what's up. It takes weeks for those parts to come all the way up here for me.
