-   -   930 crank dimensions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/473412-930-crank-dimensions.html)
pavulon 05-08-2009 10:45 AM
I've been offered a 930 crankshaft with the following dimensions:
Yes the crank checks out. The numbers are Mains 2.243, Rods 2.046, Thrust 1.104, Snout 1.220
Are these acceptable? The asking price is $500 and it has been determined to be crack free via magnaflux.
Thanks for any help.
tom1394racing 05-10-2009 05:50 PM
Here's some inspection data for a 3.2/3.3 crankshaft
UL=upper limit for new shaft
LL=lower limit for new shaft
wear limit= rebuild limit
data is in mm
25.4 mm= 1 inch
http://forums.pelicanparts.com/uploa...1242002776.jpg
http://forums.pelicanparts.com/uploa...1242002797.jpg
