FUSHIGI
930 crank dimensions
I've been offered a 930 crankshaft with the following dimensions:
Yes the crank checks out. The numbers are Mains 2.243, Rods 2.046, Thrust 1.104, Snout 1.220 Are these acceptable? The asking price is $500 and it has been determined to be crack free via magnaflux. Thanks for any help. |
Here's some inspection data for a 3.2/3.3 crankshaft
UL=upper limit for new shaft LL=lower limit for new shaft wear limit= rebuild limit data is in mm 25.4 mm= 1 inch ![]()
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
