2.7 with a 3.0 crank
A friend of mine is considering a motor purchase. Its a 2.7 that seems to be rebuilt right (shuffle pinned, oil squirters, new pistons and cylinders etc) but the seller says it has a 3.0 crank.
My questions is regarding the crank....what does a 3.0 crank offer in terms of performance or reliability over a 2.7 crank.
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 05-14-2009, 07:02 PM
The cranks are completely different and not usable in opposite applications.
the 76/77 3.0 Carrera used a 2.7 crank and rods with 6 flywheel bolts
the 78 and later used a 9 bolt flywheel although the stroke is the same the rods are not identical, as they use different bearing shells
Bruce
Old 05-14-2009, 07:09 PM
Thanks Bruce. It will be in the shop next week so we'll figure out what the motor is at that time.
Old 05-15-2009, 06:16 AM
Bruce, TRE told us that it was a 2.7 with a 3.0 from a 76/77 turbo......seems that they have the same bolt pattern.
Old 05-21-2009, 05:40 AM
I own a 76 930 and indeed it does have a 2.7 crank. All 74 to 77, Carrera, Carrera Turbo, and 2.7 S used the 70.6mm stroke crank and it was in fact a 2.7 crank.
The 78 and later 3.0 used 70.6mm stroke but different rods and bearing sizes but stroke remained the same.
What ever the crank orgin, its a 2.7 and was used in the 3.0 /carrera 3.0 and Carrera Turbo 76 and 77 only
Bruce
Old 05-21-2009, 06:35 PM
356RS's Avatar
70.4 stroke
Mark Jung
Bend, OR
MFI Werks.com
Old 05-22-2009, 09:24 AM
