-   -   2.7 bore alignment (http://forums.pelicanparts.com/911-engine-rebuilding-forum/475146-2-7-bore-alignment.html)
4sd911 05-18-2009 02:28 PM
2.7 bore alignment
That holds the two case half's in alignment on a 2.7. I see the two round locks at the main bearing near the fly wheel. What keeps the case aligned at the rear of case? Does the nose bearing serve this purpose?
afterburn 549 05-20-2009 07:36 PM
shuffle pins
MBruns 05-21-2009 05:09 AM
Alignment
The nose brg. #8 is the alignment for that end, shuffle pins are in addition to that for keeping it where it belongs.
Mike Bruns JBRacing.com
afterburn 549 05-21-2009 09:02 AM
You should pay for a shufflel pin job...not very spendy Plus all the other up dates for a mag case. (Then they are a great unit ! )
