-   -   help needed-replacing shift rod coupler bushings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/475158-help-needed-replacing-shift-rod-coupler-bushings.html)
fredmeister 05-18-2009 04:11 PM
===============HELP ADVICE WANTED=============
I removed the rear tranny shift rod coupler and am trying to replace the plastic bushings that are held in the diecast aluminum housing. I am trying to figure out how to push out the steel pin that is pressed into the splined steel yoke that is captured between these bushings.
I tapped on it hard with a hammer and punch and it don;t budge.
I had researched the forums already with the search feature and cannot find any specific forum post that deals with removing this pin and replacing these particular bushings. I don't have a press at home but a good bench vise and some hand tools.
How do I remove this center pin? Don;t want to break the aluminum coupler housing in the process.
Fred
Flat6pac 05-18-2009 07:27 PM
It will drive out.
Place it on a socket and drive it through. Use the big Porsche hammer or put it in a vice with a couple sockets, one to drive it into and another to push it through
Watch the oval direction when you install the bushings
Bruce
