which heat exchanger would you use?
G'day everyone
I have a dilemma regarding my 3.2 rebuild. I have two sets of exchangers:
  • a 3.2 set
  • a freshly jet coated set for a 2.2
The 3.2 has the thicker flanges + the extra length of pipe that stops the reduces the failure of the gaskets.
The 2.2 has the benefit of being jet coated ($400!)
Which set would you use?
TIA
R
Old 06-01-2009, 03:53 AM
Free minder
Aurel's Avatar
I would sell both and buy a set of SSIs. Dilemna solved!
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 06-01-2009, 04:02 AM
what are they worth?
Old 06-01-2009, 05:24 AM
Free minder
Aurel's Avatar
I`d price the dirty ones at $150-200 and the clean ones at $350-400. You can check prices in the PP classified section or e-bay. That might raise you enough cash for a pair of used SSIs. But other points to consider are emissions in your area, and the fact that you will still need a two in muffler for the SSIs and updated oil lines. Really depends on your budget. Otherwise I would use the thick flange after a good sandblasting and sell the thin flange.
Old 06-01-2009, 06:14 AM
