-   -   Clarifying the dream 3.0 build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/476094-clarifying-dream-3-0-build.html)
Brother 05-23-2009 10:45 PM
I'm starting to narrow the field of potential cars to buy. I'm really closing in on 78-79 SC's. I would like to get the car and do some bolt on mods and then eventually do a rebuild for the final push. The goal would be to make a 10lbs/hp car.
Starting with a large port 3.0
Bolt ons - PMO's (40 or 46's?) or ITB EFI
SSI's
M&K muffler
Mods for engine rebuild:
98mm pistons and cylinders
Twin Plug
12 plug dizzy
Tranny cooler
cams (unsure of grind)
Questions:
Am I out to lunch with my wish to get around 250-270 hp with good low to mid range torque?
Is there a better or more common accepted solution for this problem?
Are there any problems that I need to pay attention to or look out for?
Is there really any benefit to the big port heads on the early SC's?
Brother 05-27-2009 09:06 AM
bump for the long weekend.
BARknucklehead 05-27-2009 09:32 AM
SSI's
M&K muffler
Twin Plug
12 plug dizzy
Tranny cooler
Questions:
You aren't out of line at all. A short stroke 3.2 should be able to get there without issues with the right cam choice.
Good read:
http://forums.pelicanparts.com/porsche-911-technical-forum/452730-what-best-cam-set-up.html
http://forums.pelicanparts.com/911-engine-rebuilding-forum/460737-question-all-those-who-have-3-2l-short-stroke-w-46mm-pmos.html
http://forums.pelicanparts.com/porsche-911-technical-forum/362326-first-dyno-run.html
http://forums.pelicanparts.com/911-engine-rebuilding-forum/343827-wanna-build-ss-3-2-a.html
These should answer most of your questions.
