pitted crankshaft
Can a crankshaft measured within spec except for a tiny shallow pit on the rod bearing surface be used without further grinding? Your opinion, Thanks!
'87 3.2 Targa
Old 05-30-2009, 06:44 PM
A pit and not a flat spot will simply fill with oil and the metal around it will still support the bearing.
Bruce
Old 05-31-2009, 07:37 PM
Bruce, thanks! That's what I thought but I need someone with experiences or an engineering background to confirm it.
Now there arises the question of how big a pit can be categorized as a flat spot.
'87 3.2 Targa
Old 05-31-2009, 09:09 PM
Almost Banned Once
sc_rufctr's Avatar
Is it raised at the edges at all?
Take a good macro picture of the pit and post it here with a .044 inch (1mm) drill bit tip next to the pit for comparison.
(I used to be a machinist)
- Peter
Old 06-01-2009, 03:42 AM
Peter, thanks a lot!
Looks like not raised but I'll take a picture after spliting the case. At this moment it's really difficult to get adequate illumination for the pit through the crack of the engine case. I'm still waiting for the cam tool from our host to disassemble the engine.
'87 3.2 Targa
Old 06-01-2009, 06:45 AM
Almost Banned Once
sc_rufctr's Avatar
Ok... I'll keep an eye on this thread.
Good luck with the disassembly.
- Peter
Old 06-01-2009, 05:00 PM
