Dan Morton's Avatar
Sachs clutch question
I have a sachs clutch in my 1968 911 and am getting ready to put the rebuilt engine back in soon (2.0 with 2.8 RSR pistons). The car came with a Sachs clutch and best I can tell it was okay for the short time I was able to drive the car before tearing it down.
I took measurements and it's 9.27mm thick. It looks to be okay and it does not look completely worn out. I'm not sure how a new one would compare.
Any thoughts on how I can tell? There are no numbers on the clutch that I can read any more.
I can always put another one in at a later time but would just like to get an idea on how to tell the amount of wear.
Thanks!
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 06-01-2009, 07:26 PM
Dan Morton's Avatar
Correction. The clutch is a Centerforce Performance Clutch. I'll call them tomorrow as well.
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 06-01-2009, 08:26 PM
304065's Avatar
It is a good idea to use a new clutch disc at every rebuild of the engine.
What you should really be concerned about is the flywheel- replacing the clutch is easy if you find it's too thin. Replacing the flywheel is impossible without an engine drop.
Above image Copyright Porsche KG 1967- posted here for educational fair use only
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-02-2009, 05:22 AM
Dan Morton's Avatar
Thanks John!
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 06-04-2009, 05:32 PM
