-   -   Rocker arm rebuild advice (http://forums.pelicanparts.com/911-engine-rebuilding-forum/477707-rocker-arm-rebuild-advice.html)
milspam 06-02-2009 05:59 AM
In preperation of top end refresh and new cams, can anyone advise who to send rocker arms to for refurb? Also, got any input as to cost? Thanks, milspam
jaybird840 06-02-2009 06:25 AM
without question, send them to John Dougherty ("Camgrinder" on this board) I can't give a price as mine were done in a package deal with my camshafts. Good work, great reputation, excellent support.
CBRacerX 06-02-2009 06:43 AM
+1 - great service.
jsmithcds 06-03-2009 06:13 PM
rocker arm refurbish
Delta camshaft did mine. $6 a piece for resurface if no welding needed to be done.
Had them back in the mail next day. Very quick turn around.
John did my 964 grind +1
911pcars 06-03-2009 09:30 PM
That might depend on the source of the cams. For example, Webcam reground cams use a hard weld process. They suggest new rocker arms or rockers with rehardened tips. Last I looked, they want about $65/rocker to reharden and regrind. You could shop around and source new rockers for that price.
Camshafts with original iron cam lobes seem to do okay with refurbished rocker arms (as long as the hardened friction surface at the tip is still intact).
Sherwood
strokher racing 06-04-2009 08:37 PM
I would go with John. He always does me right!
Ken911 06-22-2009 06:10 PM
Any one here have the part number for the bushings? i want to rebush mine when i take it apart.
KTL 06-26-2009 02:26 PM
I'd contact cgarr (Craig Garrett) here on the forums. He refurbs rocker arms with a permaglide bushing better than the original bronze bushings. He could point you to some testing he did on Motodelta GruppeB forums and you'll see some testing he did with these bushings.
Craig also squares the faces on the cam lobe pads and it's my understanding that he's found the pads need very little in terms of refacing, so the hardening is not greatly disturbed?
jacksd3 06-27-2009 06:14 AM
+1 for camgrinder
T77911S 07-02-2009 07:53 AM
did that include bushings?
