Closed Thread
lespaul's Avatar
Advice? 1973.5 Engine Work/Leakdown Test
I have a 1973.5 T with 185,000 miles. It has never had a top end job or any engine work. Records show regular oil changes. Until a few weeks ago, it was running fine. Now, upon deceleration (and especially when engine is "braking" on long down hill runs) it blows a lot of bluish smoke. Another big smoke cloud upon acceleration -- but then with steady running the smoke disappears. It also seems to be running much hotter than it used to.
From reading the threads, I am guessing I have a bad valve guide (or guides). With a car with this many miles on it, I may have other engine issues that should be dealt with. So, before I dig into either a) just replacing the guides, b) doing a top end rebuild, or c) doing an entire rebuild (ouch), I think I should have a leakdown and a compression test performed. I am hoping that these tests will help me pinpoint whether I have a bigger problem than just valve guides. For what it is worth, the prior owner's records show a compression test done at 125,000 miles with 130 lbs compression on all cylinders.
Does this make sense? If so, specifically what should I ask the shop to do? And, can anyone recommend a shop in the Southern Vermont/ Western Mass area to do a good leakdown and compression analysis?
Brad Fawley
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 06-17-2009, 10:58 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #1 (permalink)
304065's Avatar
Thou shalt not post in multiple forums lest the Forum become confused and throw up its hands!
Redirect:
Advice? 1973.5 Engine Work, leakdown- VT/Mass
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-17-2009, 11:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    #2 (permalink)
Closed Thread
