I'm here to cause trouble
jimbauman's Avatar
One more attempt at the connector thread...
Does anyone have a pinout chart/diagram for the wiring harness connector that plugs into the side of the 3.2 engine compartment fuse/relay holder?
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 07-04-2009, 11:54 AM
Manassas, VA
lucittm's Avatar
Jim,
I can't help you with the chart/diagram because my 1991 wiring diagram is different. But, what I found out is that the corresponding connector that mates with the one in the picture will have the same pin out with the same wire colors. All you have to do is match the positions 1-14 with the positions that are filled with the appropriate colored wire
Also from your picture above I bet that if you start with - YE, GN, GN/YE, GN/WT, UNK, YE/UNK on the top row and - RE, GN/UNK, BN/GR, BN/BL, RE/UNK on the bottom row, you would be at a good starting point based on the length and the orientation of the wires.
Good Luck,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 07-04-2009, 09:03 PM
safe's Avatar
I did a diagram not that long ago, but I can't find it now.
I tested with a resistance meter what the pins was connected to and used the Haynes manual to find out to what number in the connector it should be connected.
Magnus
Old 07-05-2009, 12:47 AM
jimbauman's Avatar
Thanks guys. I ended up disassembling the other connector (being VERY careful not to let anything pop out!) and mapped it out. I did notice one instance where the colors didn't match up! Vagaries in wiring harness of the day I imagine...
JB
Old 07-05-2009, 12:14 PM
