I am rebuilding the top end of a 1972 911T and dropped a nut from the timing chain housing into the case. It fell in on the passenger side when it was facing up. I immediately rotated the engine 180 degrees hoping it would fall out, no luck. Next I removed the timing chain (split chain) and searched with magnet and blasted with compressed air, still no luck. Finally I borrowed a fiber optic bore scope and inspected the entire area and can not see it anywhere. It appears that the timing chain area on the passenger side is an enclosed space but I assume I must be missing some opening to the main case or some other hiding spot. Any suggestions?
Autobahn Garage
Split the case, Sorry to hear about this happening but I have done the same thing. You might turn the engine on it's back (flywheel side down) and shake it and see if you can break the nut free. Put magnets in the oil return holes as well as the bottom sump plate area, you might get lucky
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
If you have waynes book, you can see a pic of a split case. This will give you an idea of where it can hide. And where to look.
But splitting the case is a lot of work. I would persevere - thru the oil drain plate, take the other chain cover off, if not already. Rotate the engine casing every which way , listening for a clunk. I would spend a few hours doing this before splitting the case. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Another thought - the oil will make it quite sticky. You might try flushing the residual oil out with a bit of petrol - put half a liter in, slosh around and drain. That may free the nut up to move around, or be seen. It may have been submerged in a pocket of oil.
Alan
harvardma, I dropped a keyway off of a cam in mine and had to split the case. I never did find it, but I am getting a 3.4 for all my trouble.
I did find that the intermediate shaft bearings were worn, so I probably should have split anyway.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
split the case !!,this is what I lost and then found by splitting the case after searching the workshop floor and bins for hours
Exactly as it was found sitting there ready to grenade and destroy my engine
www.facebook.com/pages/Bournville-Frameworks |
Order a Stahlwille 500g magnet tool, 12600-500g. Use this to fish inside the engine, if it's in there, you can find it.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
John:
Good tool. Where can I obtain one of these? Thanks.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
www.samstagsales.com Wayne doesn't sell Stahlwille. Talk to Andrew Poston.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 07-09-2009 at 06:58 PM.. |
Nice catch, I hate it when I loose a fastener when I am building a motor, one can drive themselves nuts looking all over the shop floor for it, trying to figure out, if it is indeed in the motor.
I dropped a small 10 mm nut down the intake of a 5.4 triton while doing head gaskets. I did not notice it. Lit the motor, all was well for about 5 seconds, and Kaboom!!!!, mass destruction, actually broke through the cylinder bore, holed a piston, and bent a rod, oops.
No left turn un stoned |
After further disassembly (removed timing chain cover and chain ramps) I was able to spot the nut hiding under the intermediate shaft gear. I tried to recover it with a magnetic probe but could not get it into the right location (the tool John posted would have worked). I also tried with a piece of wire but just pushed it farther under the gear. Finally I put a small amount of mineral spirits in to get thin out the residual oil and hoisted engine with flywheel side up and it fell out onto the floor. Thanks for all the advice!
I'm glad you guys had happy endings.
For a change-of-pace reference point, can someone post some pics of the bb's into the intake manifold of a 4-banger? Sherwood |
been there, done that. spent almost 3 hours fishing out a nut that got dropped into the oil return tube. magnet, and a light are your best friends.!!
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
I once "lost" a nickel-sized nylon washer in my 964 that I was using as protection for the mechanical chain tensioner devices. What a PITA. No magnet to fish since nylon isn't magnetic. I spent hours searching for the bugger with a tiny flash light and eventually found it sticking to the inside case wall due to residual oil in the crankcase. I know how frustrating this can be...... good job finding yours.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
