-   -   Guess how much is left! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/487948-guess-how-much-left.html)
RichHawk 07-26-2009 07:49 PM
First Post, new member.
I've been lurking and reading a bunch. I just bought a 1987 911 Targa with significant engine damage. At least I knew that when buying it, and my only surprise is just how much any 3.2L replacement engine costs.
123K miles, with aprox 40K miles on a (questionable) rebuild. I say questionable because it was leaking oil like a sieve, and combine that with an ignorant owner, resulted in the poor targa getting run out of oil. At highway speeds. Until it locked up the rear wheels.
I got absolutely no documentation on the service history, but the car is in exceptionally good shape for it's age. Zero rust anywhere, and a few small door dings and bumper scratches is all that is cosmetically wrong with it.
SO onto the engine....
I bought the car, pushed it onto a trailer and when I got it home filled it with 6.5 qts of oil and fired it up. Whoopee! it runs. But jeeze did it sound bad! Rod knock does not begin to account for the noise. It was more like rod not attached to a piston sound.
So I drained the oil, just to see what came out, and it was not pretty. I got lots of tell tale bearing material, and a chunk of what appears to be connecting rod wrist pin material. Oil Tank and sump drained less than 8 qts of oil.
Engine is coming out this week. Tear down should be ....Interesting..... to say the least. I'm most probably in the market for a replacement 3.2L of some sort.
Speculate with me: How much might be salvageable in my engine?
I am expecting crank, rods, and at least one piston / cylinder are toast.
I've had a knowledgeable Porsche engine builder speculate that even the Valve springs have been overheated and lost some of their spring-rate.
Maybe I'm dreaming to hope that the cases and heads and cams are usable.
What's your opinion?
Thanks,
Richard in Kansas City
http://forums.pelicanparts.com/uploa...1248662863.jpg
http://forums.pelicanparts.com/uploa...1248662884.jpg
longhornchris04 07-26-2009 09:42 PM
camshaft is probably toast as well... honestly you are probably better off just getting a fresh 3.2.
If it were me, I'd drop in a new 3.2, then tear down the poor motor and sell anything that is salvageable. My guess would be:
Case & timing covers
Heads (maybe, maybe not - camshaft bearings could be gone)
uh... thats actually all I can think of.
Ok, so your crank may be salvageable if it can be reground and use oversized bearings... Those thinks can handle an amazing amount of force, its the bearing surfaces that get messed up.
Also, major word of caution - check the front fender cooler and lines for debris. Then check them again. Then check a third time... it would suck to have a new/rebuilt motor die because there was something in your oil cooler.
Other than the engine, you have a nice looking vehicle.
Now, excuse me while I go throw up... carnage like that turns my stomach.
euro911sc 07-27-2009 06:31 AM
+1 on buy a new used engine and scrap the old one.
+1000 on clean out the oiling lines + cooler!!!
If you get a new used engine for $4-7k you can enjoy the car (nice looking car!) while you have tons of fun ripping the engine apart and learning about it. Contrary to LongHornChris I love to see carnage and then read the commentary from everyone so post up lots of pics ;)
You may find that the case is usable as desk legs ;) Heads and cylinders make great trophies and pistons are great paper weights. I have a few blown ones on my desk :) and people love to pick them up and play with them.
Enjoy!
-Michael
RichHawk 07-27-2009 06:32 AM
Originally Posted by Noah (Post 4800938)
The valve covers should be usable.
But seriously, I would be very scrupulous about selling internal engine parts from that motor. Be upfront with potential buyers about where the parts came from...
Uh, no worries on that: I know very well the amount of detail and documentation that should go along with anything used and Porsche. I would be VERY upfront and detailed before I sold anything. Though I suspect that some of it will become decorative for my garage wall.
Lack of Immediate funds prevents me from buying a "New" rebuilt motor. But a good running "needs freshened" motor that I can rebuild myself is within my financial grasp.
So I'm truly looking for more opinions from those that have seen this carnage before, and maybe a sentence on who you are, as I do not have the years of history with this group to intuitively know your experience level.
Thanks for playing along!
Richard
RichHawk 07-27-2009 07:01 AM
Oh, and I guess specifically I don't know a lot about air cooled engines and what goes bad when things run out of oil. Ok, Ok the obvious bearings munch themselves and pistons seize. But it's the unique to air cooled overheating that I don't have experience with...
My water cooled experience is overheat = Cracked blocks or heads, but the valve gear is usually fine (But so are the crank, rods, and cams because they have oil to lube them, and cool them.)
In the 911, with no oil to act as a secondary cooling media, does the entire engine just get blazing hot? Doesn't the fan provide the majority of the cooling? or is the oil more than 50% of the cooling capacity?
Could overheating really change the spring characteristics of the valve springs? Galling and seizing I can understand, but changing the properties of spring steel? I think the aluminum heads would be puddles on the ground before that could happen.
Of course I've put zero math (or better yet, Zero practical Porsche experience) behind that claim, so I'm looking for expert opinion.
I'm just trying to make sure I wrap my water cooled mind around the air cooled engine as fully as possible. And I'm using this as a mental exercise as I sit here at work, instead of dropping he engine like I want to.
I'm definitely going to fully examine and measure the cam housing and cams. But the heads themselves? Other than Valve guide slop, I'm limited to visual examination. and then taking the heads to a competent machinist to check for warpage, and check the springs for proper rates. What else could go wrong on an overheated Air cooled head?
Wayne's book is on the way. It can't get here soon enough.
Thanks,
Richard
longhornchris04 07-27-2009 08:58 AM
If/when you do tear it down, be sure to post pics. I have a morbid curiosity :)
As to heat damage, the oil is used to cool anything that can't get air easily. The heads could easily have overheated before the engine froze. Honestly, even if the springs showed the proper rate, I wouldn't reuse. A good bit of the cost is just getting in there to replace them - everything I've read says if you are in there, replace them. My concern is less about heat damage (which is bad), but more about the camshaft bearings. If they got spun, then your heads may not be reusable.
In addition to direct heat damage, high head temps can lead to detonation - which can cause spectacular damage to the valves and heads.
Oh - the oil is also used to cool the pistons - Porsche installed oil sprayers in the case that bathe the underside of the pistons with "cold" oil to remove heat from the underside. W/o this, the pistons probably overheated, expanded, and froze.
Finally, at least in race setups (multiple external coolers), it has been shown that the oil provides more cooling than the fan. In a stock config, I'm not sure, but there are stories of racers throwing their fan belts and the engine surviving... not that I'd recommend this. The air cooling seems to mostly get the cylinders, part of the heads, and the engine-mounted oil cooler.
Good luck. And pics, we want pics!!!
Aurel 07-27-2009 05:41 PM
I have the opposite problem...a freshly rebuilt engine and transmission that runs very well, but a worn interior and a body that badly needs a paint job. Your car looks beautiful !
afterburn 549 07-27-2009 09:48 PM
I am usually a strong advocate of rebuild what you have......but in this case.....You will buy all the same parts , So Just go get an other one
longhornchris04 07-28-2009 02:56 PM
Oh, one other thing. I doubt the transmission receive any damage... but I'd still flush it and check for crap. Having the engine seize at highway speed can't be good for 5th gear.
That, and anybody who lets the oil run dry probably didn't ever flush the trans.
RichHawk 07-29-2009 07:30 AM
-Michael
So I've been thinking about how to flush the cooler and lines... Removal of the cooler, and having it boiled out leaves it in someone elses hands (Which I don't like), but may provide the best result.
I also have been thinking on how to get the 1.5 year old gas out of the tank..
An a CRAZY!!! thought came to my head.
Since I'm not going to be using the gas for even my lawnmower, and I figure I have to use the fuel pump to pump it out anyway, Why not rig up the fuel line into the oil lines and cooler, and back flush all the crap out using the 5 gallons of Gas as a solvent at 40 PSI?
Then collect the gas and dispose of properly, and do a final clean flush of the lines and cooler with a gallon of Isopropol Alcohol, using a gravity flush (Hose and funnel)
I'd probably still take the cooler off after that and ensure that it came clean.
Good or bad idea?
Richard
longhornchris04 07-29-2009 09:39 AM
What kind of cooler is it? I'm assuming Carrera cooler.
I'd take it off and clean it seperatly. Back flush the lines. This way you don't drive any crap in the lines through the cooler. IMHO, you are more likely to get the crap out if you flush each piece individually. Plus, if there is a bad blockage in the cooler, you can at least get recover the lines.
Good luck.
euro911sc 07-29-2009 05:38 PM
Take the cooler off and send it out to be cleaned at Pacific Cooler or some place like that. That gas trick sounds like a great 1st pass on the lines. Isopropal wont do anything on oil sludge. I'd re-circ the gas a bunch of times until you are satisfied. Even then you wont have gotten it all, but I suspect most of it will be gone. You could also try sea foam.
Enjoy!
-Michael
RichHawk 08-01-2009 09:57 PM
Engine's out
I haven't torn into it yet, But at least it's out.
I'm fighting the shift fork needle bearings, so the transmission is still hanging on. Tomorrow maybe I'll have enough time to at least take the valve covers off.
until then, Here's the obligatory shot.
http://forums.pelicanparts.com/uploa...1249188961.jpg
Richard in KC
RichHawk 08-01-2009 10:02 PM
Oh, and a little midnight guessing game:
I yanked this out from under the Passenger seat. It took some thinking to figure out what it was, but when I got there it was an AHHHH! moment.
Wanna venture a guess?
http://forums.pelicanparts.com/uploa...1249189339.jpg
OldTee 08-02-2009 05:23 AM
radio signal amp for antenna in windshield is my guess. don't need with outside antenna.
RichHawk 08-02-2009 06:25 AM
Nope.
Other clues: It's not factory, and it's not going back in, due to being completely obsolete. SmileWavy
OldTee 08-02-2009 06:31 AM
Telephone part.
RichHawk 08-02-2009 07:08 AM
Originally Posted by OldTee (Post 4812610)
Telephone part.
WE HAVE A WINNER!!!
The guts of an old Car phone, Missing the handset.
RichHawk 08-03-2009 05:46 PM
remember me saying that the engine had a rebuild 40K miles ago? Remember I said it was questionable? Well now I think the only question is how much of a liar was the previous owner?
Ok, one truth, he did run it out of oil.
Two things so far make me think that this engine has not been open beyond the valve covers:
1) the transmission fork pivot shaft fought me the entire way out. I used the deep 19mm socket, a long bolt, and lots of washers as a puller . It was worn badly by the needle bearings and felt like it had never been removed.
2) I removed the valve covers to find two broken dilivar studs resting one on each side. But more telling is that there are four broken studs, and two of them are nowhere to be found. So I think someone had the valve covers off, noticed the broken studs, and did nothing about it except take the pieces out, and put new valve cover gaskets on.
:o
Certainly it did not get a quality rebuild.
More to come. If I'm lucky I'll have the cylinders off by Wednesday, or it will have to wait until next week.
Richard in KC
RichHawk 08-05-2009 09:35 PM
Carnage report: or Number 5 is not alive!
I knew the noise was coming from the right bank, and I speculated that it was from the middle cylinder.
SO I disassembles the right side first. Head came off with no drama, looks good, there are some small "contamination in the oil" marks on the lobes, but all in all look usable from what I can see while they are still in the head.
Rather than go through the head I wanted to look at the cylinders.
Number 5 piston was not attached to anything, so I removed the cylinder, and sure enough broken piston. But worse is the rod broke off both at the piston and at the crank.
See the carnage pics attached: Yes that black thing is the rod journal. Note the gouging the rod did to the case. any more hammering and that rod was going to come right through the case.
I won't be back home to split the cases until next week. But I've found enough to know what I speculated. Engine is D-E-D Dead!!
Richard in KC
http://forums.pelicanparts.com/uploa...1249533193.jpg
http://forums.pelicanparts.com/uploa...1249533214.jpg
http://forums.pelicanparts.com/uploa...1249533296.jpg
Don Settergren 08-06-2009 05:34 AM
You're going to need a lot more than one tube of JB Weld.:eek:
The PO must have heard some knocking and kept driving. You might have an easier project it he would have stopped at the first sign of a problem. Anyway, that's one less Porsche in the hands of a bone head. More progress photos please!!
euro911sc 08-06-2009 07:08 AM
Oh come on!!! That's just a mooned cylinder. He saved you money on a performance upgrade! Be thankful! I'd say 2 tubes of JB weld and a tube of RTV and you will be running again in no time!
-Michael
dtw 08-06-2009 07:43 AM
Unfortunately there's not much to rebuild from. You're better off getting a complete core somewhere and building that, or try your chances at a good used motor.
longhornchris04 08-07-2009 12:34 PM
Well, that's impressive. After seeing that, I'd be surprised if the case isn't warped.
Keep the pics coming.
RichHawk 08-10-2009 08:03 PM
I've got the cases apart, and everything out, and I must say, its FAR FAR better shape than I could have hoped for. Don't get me wrong, it's probably all trashed. But for being run out of oil, 13 out of 14 crank bearings are not trashed.
SO I title these two pictures:
One of these things is not like the others, one of these things is just not the same.....
http://forums.pelicanparts.com/uploa...1249959729.jpg
http://forums.pelicanparts.com/uploa...1249959759.jpg
RichHawk 08-10-2009 08:14 PM
more mass carnage
So I'm pretty sure the 6 Qts of oil I poured in before starting the engine REALLY didn't help lubricate much in that few seconds of running...
http://forums.pelicanparts.com/uploa...1249960111.jpg
Since you might notice that the intermediate shaft that drives the oil pump got violently cut in two by a flailing connecting rod.
http://forums.pelicanparts.com/uploa...1249960249.jpg
And then notice the remains of a connecting rod bolt that is wedged down in near where the cylinder slides in.
http://forums.pelicanparts.com/uploa...1249960378.jpg
RichHawk 08-10-2009 08:22 PM
So educate me about case warpage.
Symptoms? Problems? Measurements needed? What is warped relative to what else?
Richard
gearheadgreg 08-11-2009 08:15 AM
Hey Rich! Nice to see you on here, its an awesome resource.
Yeah, that looks a bit worn. I would try popsicle sticks and rubber bands to splint he intermediate shaft, cap the bad cylinder and run it as a 5 cyl boxer!
Heh. Good luck finding a used/core engine - I'll ask around. The local shop owner is putting a 3.2 in his 72 VW camper Bus (to replace the 2.4)!
RichHawk 08-11-2009 01:10 PM
I'm running cost comparisons of fixing what I can of what I have, Vs Buying different used parts, Vs buying a completely different engine. Help me out if you can:
Initial Crank shaft journal measurements show all the journals within standard specifications. Er, all but one ;)
Though this is done with just a digital caliper setup not as accurate Micrometer, so it will need to be done again. But I just had to know if it was close enough to think about welding, grinding and heat treating.
I know I know, it may never be as hard as the original finish, but put aside the "I would never risk that" comments for a second, and help me figure out just what I might expect in terms of costs.
Assume that only one journal needed welded and ground down, and the rest could be polished. (I assume any shop that would do that would also balance the crank again. Correct?)
Who has done this and at what cost?
Now assume two journals, as one was closer to the limit than the others.
RichHawk 08-11-2009 01:14 PM
Richard
Did some hunting on my own.
Validate this if you can: If the crank turns relatively freely in the cases when the cases are bolted together, can you safely say the cases are not warped and the crank is not Bent?
Don Settergren 08-11-2009 06:02 PM
Clean that case up and have a really detailed look around. You don't want to start spending money on a case that might be bad. Also, you should follow the same test process as the crank on the intermediate shaft after the hit it took. Spin to win!
Love the carnage shots - can't wait for the clean glory shots!!
TimT 08-11-2009 10:13 PM
Your missing the coup de gras on that engine...
http://forums.pelicanparts.com/uploa...1250053656.jpg
http://forums.pelicanparts.com/uploa...1250053676.jpg
http://forums.pelicanparts.com/uploa...1250053687.jpg
Probably the only salvageable parts will be the case, crank. cam towers, heads, cams....probably the head over the broken rod will need to be replaced.. rocker arms may need only one or two replaced....
You are going to have to flush the whole oil system out, remove the front mounted cooler and engine cooler and send them out for ultrasonic cleaning.. remove the oil lines and flush them..
It will probably be more cost effective to buy a 3.6 or a 3.8 from a reliable source and upgrade that way...
TimT 08-11-2009 10:19 PM
We have had many cranks reground, journals repaired, cranks offset ground for stroke, cranks center drilled for center main oil improvements..
Armondo at CCR has been good to us.... other people will post negatives about CCR regarding turnaround etc.. we haven't seen that
TimT 08-11-2009 10:32 PM
Also reading back and forth through this thread, you question if a reground crank journal will be of the same hardness....
Yes...the guy we use re-hardens the crank after machining... the whole crank... you will get a line on the bill for disposal of hazardous materials.. the pickling salts...
drb930 08-11-2009 10:55 PM
Hi Richard,
After seeing the pictures of that Crank I don't think I would run that in any engine.
Looking at the picture, it looks like part of the "Cheek" of the Crank is missing at the top of the journal.
Thanks,
Dave
RichHawk 08-12-2009 07:52 AM
Originally Posted by drb930 (Post 4831274)
Hi Richard,
Thanks,
Dave
Are you talking about the non machined webbing that is on the left and right of the bad rod journal surface? Though dented, that part is not missing any material. the picture is deceiving. Here's a better one:http://forums.pelicanparts.com/uploa...1250088716.jpg
Richard
RichHawk 09-17-2009 08:09 PM
Tough lil bastad
I got myself a set of metric Micrometers 0-100mm and of course had to go to town measuring things.
This is one tough engine. Despite losing a connecting rod from BOTH ends, most everything is still within specs. Of course the one bad rod journal is not, but it looks as if it could be ground down to -0.5mm undersize. Every other journal (Rod and main) are within factory spec.
Try running a small block Chevy out of oil and you would get a completely different result.
I'm actually a bit sad at not actually fixing the crank and cases to give this engine a second chance. But it looks as if I'm picking up a whole other 3.2 from a pelican member that already had most of the machine work done.
Richard
911 tweaks 09-18-2009 05:29 AM
don't be sad... you will hopefully be re couping some of your $$ spent on the replacement engine by selling what you can from this engine. A lot better than trashing the entire engine as I know of 1 shop that did to a customer!!
Best of luck here and you are making the wise decision to get another engine.
**Just do not forget to remove the hard oil lined & what ever oil cooler set up you had and ultrasonically clean or better yet, replace them. I have herd of after such being ultrasonically cleaned that not all of the debris was removed and the replacement engine was trashed on the guy...
Bob
911 tweaks 09-18-2009 05:31 AM
Bob
kepperly 07-03-2010 03:20 AM
How much for the alternator mounting ring. Just the ring no fan or alternator. Shipping to 67230. Please email price with shipping to kepperly@sbcglobal.net.
Thanks Keith Epperly
