B D B D is offline
B D's Avatar
Piston Circlip Size
I just noticed the new 22 mm piston circlips from Porsche I got are longer than the ones I removed. They are the correct diameter but have a much smaller space between the clip opening. Do I need to cut them?
68 911L
Old 08-09-2009, 06:55 PM
B D B D is offline
B D's Avatar
Started cutting them, even if you could get them in they would overlap or not hold the pin.
68 911L
Old 08-09-2009, 07:22 PM
