Magnetized intermediate shaft?
Should the intermediate shaft be magnetized? Mine is and there are some metal bits clinging to the inside. Any easy trick to get them out?
Old 08-20-2009, 08:48 AM
magnet
Find someone that has the wet type of magnaflux inspection (aircraft engine shop) they will have demagnetizing equipment for post inspection. then you can clean it properly. One other source is a good crankshaft grinder, Armando at CCR in Ca. can help you.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 08-21-2009, 05:42 AM
Mike, do I assume that it's should not be magnetized?
Old 08-21-2009, 11:05 AM
magnet
thats correct, it needs to be de magnetized
Mike
Old 08-21-2009, 07:26 PM
Thanks Mike.
Old 08-21-2009, 11:57 PM
If you can demag to around 2 Gauss it would be good.
Old 08-22-2009, 12:45 AM
