Shroud paint
Looking for a recommendation for a type of paint to use on the engine shroud pieces. I have a spray can of Wurth high heat resistant paint, will this resist scratching? I see it needs to be heated to cure. There is a firearms paint made for machine gun barrels that air cures in 5 days, I've used this before and it is very hard to get off after curing. You can see it here.
Old 08-16-2009, 04:38 PM
Less brakes, more gas!
euro911sc's Avatar
Engine Shroud Painting, Help!
Best paint long term for fan shroud? Krylon? Plastikote?
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-16-2009, 06:50 PM
Good reading. Just to clarify, I'm looking at painting the metal pieces.
Old 08-16-2009, 07:30 PM
safe's Avatar
You don't need heat resistant paint for that. Powder coating is probably the best choise, but I have used common rattle can paint that has worked good.
Magnus
Old 08-17-2009, 01:02 AM
3 restos WIP = psycho
kenikh's Avatar
Powder is best, but rattle can BBQ grille paint works great, too.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-17-2009, 11:25 AM
euro911sc's Avatar
Ah, I drilled out the rivits and painted it with high temp flat blk engine paint after bead blasting.
-Michael
Michael
'13 Cayenne GTS
Old 08-17-2009, 04:11 PM
On second thought the firearms paint may not be a good idea, it needs a foundation, on a firearm that would be parkerizing. If a suitable primer could be found it is very tough paint.
Old 08-17-2009, 09:08 PM
Max Sluiter
Flieger's Avatar
The shroud is not painted, it is dyed in the resin/gelcoat. You can lightly wet sand it and polish out scratches to bring back the original shiny color.
Or, are you talking about the metal air deflectors that go around the cylinders?
Old 08-17-2009, 11:41 PM
The metal pieces.
Old 08-18-2009, 06:41 AM
AutoBahned
RWebb's Avatar
satin is the OE finish - flat will be duller than original
but... the shinier the finish, the less grunge will stick to it
Old 08-23-2009, 03:12 PM
I've started painting the 8 piece's to the cylinders using the Wurth heat paint. I will use a heat gun to heat the parts above 400 deg. to cure it.
Old 08-23-2009, 03:50 PM
