-   -   Nuts, lock washers, spring washers, cylinder head nuts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/493823-nuts-lock-washers-spring-washers-cylinder-head-nuts.html)
jimbauman 08-23-2009 06:39 PM
It's a slow news day, so.... nuts, washers, lock washers, spring washers, cylinder head nuts - All of these things are specified in PET as the official fasteners to attach the transmission to the engine!
What I found interesting was the configuration on the non-starter side of the assembly. On the upper transmission stud you use an M10 nut and regular washer. But on the lower stud, you use a regular washer, a lock washer and a nut. Why the difference?
Over on the studs that hold the starter, you use two cylinder head nuts and spring washers. Why not lock washers?
JB
Flat6pac 08-23-2009 06:43 PM
I ve never seen a double washer there and thats dozens of r&r s
Bruce
jimbauman 08-23-2009 06:46 PM
I know - me neither - but it's right there in PET! Makes one wonder what other odd things you could find there....
JB
