I'm here to cause trouble
Nuts, lock washers, spring washers, cylinder head nuts
It's a slow news day, so.... nuts, washers, lock washers, spring washers, cylinder head nuts - All of these things are specified in PET as the official fasteners to attach the transmission to the engine!
What I found interesting was the configuration on the non-starter side of the assembly. On the upper transmission stud you use an M10 nut and regular washer. But on the lower stud, you use a regular washer, a lock washer and a nut. Why the difference? Over on the studs that hold the starter, you use two cylinder head nuts and spring washers. Why not lock washers? JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
I ve never seen a double washer there and thats dozens of r&r s
Bruce |
I know - me neither - but it's right there in PET! Makes one wonder what other odd things you could find there....
JB
