Rod bearing question?
I removed 1 rod without splitting the case.
Does this mean I have to replace the rod bearing no matter what. Even though it looks fine?
Or could I reuse the old one.
Thanks,
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 09-01-2009, 02:03 PM
Bearing don't have to be replaced, factory rod bolts and nut need to be replaced as they are stretch bolts and are only intended to be used once.
Old 09-01-2009, 04:04 PM
Thanks 4sd911,
Thats kind of what I thought I just wanted to confirm it and run it by you guys.
Reason being I thought my machinist said I had to replace it today when I met with him. I probably mis understood him.
Thanks,
Leakproof.
Suspected track car
Old 09-01-2009, 05:21 PM
Just make sure the two parts go back in the same way with the numbers on the same side and pointing in same direction.
Old 09-01-2009, 07:29 PM
Will do, Thanks.
Suspected track car
Old 09-02-2009, 11:52 AM
