-   -   Please identify metal bits in case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/496648-please-identify-metal-bits-case.html)
Derkbarrington 09-04-2009 05:14 PM
The nightmare continues. I found these metal bits in my sump .... any idea where they come from?
http://forums.pelicanparts.com/uploa...1252109509.jpg
Thanks!
cgarr 09-04-2009 05:46 PM
Looks like a coin, someone drop it in the oil breather maybe?
billybek 09-04-2009 06:31 PM
Not just a coin, that is the Bluenose on there eh!
Are they attracted to a magnet?
Flat6pac 09-04-2009 07:29 PM
Looks like there must be a piston missing maybe an oil control ring
Derkbarrington 09-04-2009 07:36 PM
They are magnetic. All oil rings are accounted for except the one I broke but these bits are separate from the oil ring.
spence88mph 09-04-2009 10:10 PM
lol!
Derkbarrington 09-05-2009 06:00 PM
To be safe I split the case. I discovered an oil leak on the bottom front corner of the motor where I also found some more metal bits. I am still at a loss to what the bits are but they didn't damage the motor and the internals look good.
http://forums.pelicanparts.com/uploa...1252198655.jpg
http://forums.pelicanparts.com/uploa...1252198692.jpg
http://forums.pelicanparts.com/uploa...1252198723.jpg
http://forums.pelicanparts.com/uploa...1252198752.jpg
cgarr 09-05-2009 06:20 PM
Is the big snap ring still on the front of your crank at the dizzy drive gear? Is that a chip our of your alum pump gear?
4sd911 09-05-2009 06:32 PM
Have you removed the intermediate shaft yet? Is that bearing parts from the shaft bearings?
Derkbarrington 09-05-2009 06:51 PM
The gears all look good with no chips. I will check the snap ring in the morning. Thanks!
356RS 09-06-2009 08:50 AM
That one intermediate shaft bearing in the picture shows excessive wear compared the the main bearings. Waiting to see more pictures.
Steve@Rennsport 09-06-2009 10:00 AM
Its not abnormal to see main bearings in excellent condition and intermediate shaft bearings worn down to the copper layer. We see excessive wear in situations where certain stiff, racing valve springs are used.
I'd ask what oil was being used and how often it was changed.
Derkbarrington 09-06-2009 03:28 PM
I've only owned the car for a few months. I bought it for $5,000 with no history but judging by the condition of the body and excessive rust on the rear inner fender and rockers, I know it was not taken care of. I own a 964 as well and took on this project first before I attempt a rebuild on the 3.6.
I will post more pics once I remove the oil pump.
Flat6pac 09-06-2009 06:11 PM
If the engine was repaired but not split, say you blew a piston, swallowed a valve, etc and some junk was left inside it would find its way to the oil pump area and just rest there,.
I have seen that before.
Bruce
john walker's workshop 09-06-2009 08:45 PM
valve spring bits? the spring seat also has a lip that can get beat up, rounded over and broken off when a broken valve spring beats on it for a long time. seem plenty of them with no remaining lip at all.
Derkbarrington 09-07-2009 04:21 PM
Well its not the bearings and everything in the case is intact... I agree the bits are probably from a previous repair or heads.
Time to order more parts from our host
911 tweaks 09-08-2009 03:44 AM
great news!! s you proceed with your rebuild, post all of the progress here or if you start a new thread post that here also!!
Good luck & do you live anywhere near the Carnival hotel of univ of NB?? Spent a lot of time up your way w/ Baxter reps. Know Freddie Savoi??
Bob
Derkbarrington 09-08-2009 10:35 AM
I live about 5km's from UNB. Next time you visit ge me a shout :)
911 tweaks 09-08-2009 11:25 AM
Derk... funny slip there on my last post... I ment to type Carnival Hotel OR the UNB. I believe that is the name of the hotel that has a carnival wheel inside it... it is located at a rotary very close to UNB... I have not been up that way since 92'... pm me if we need to discuss further as I do not want to interrupt this thread.
Bob
boxermania 09-08-2009 02:48 PM
See if you can match the broken pieces by the way they broke apart, it might give you an idea of the diameter of the object and that should narrow the search down.
I do tend to agree with one of the posters in so far as it might be the result of a prior problem, where the case was not split and the parts found their way to the bottom of the case.
Derkbarrington 09-08-2009 04:10 PM
I am convinced something must have went down the oil return tubes during a previous repair. Everything seems to be in order with no parts missing or damaged.
