Eastern Canada
Derkbarrington's Avatar
Please identify metal bits in case
The nightmare continues. I found these metal bits in my sump .... any idea where they come from?
Thanks!
Old 09-04-2009, 05:14 PM
abit off center
cgarr's Avatar
Looks like a coin, someone drop it in the oil breather maybe?
______________________
Craig
G2Performance
Old 09-04-2009, 05:46 PM
UnRegistered User
billybek's Avatar
Not just a coin, that is the Bluenose on there eh!
Are they attracted to a magnet?
Bill K.
Old 09-04-2009, 06:31 PM
Looks like there must be a piston missing maybe an oil control ring
Old 09-04-2009, 07:29 PM
Eastern Canada
They are magnetic. All oil rings are accounted for except the one I broke but these bits are separate from the oil ring.
Old 09-04-2009, 07:36 PM
spence88mph's Avatar
lol!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 09-04-2009, 10:10 PM
Eastern Canada
To be safe I split the case. I discovered an oil leak on the bottom front corner of the motor where I also found some more metal bits. I am still at a loss to what the bits are but they didn't damage the motor and the internals look good.
Old 09-05-2009, 06:00 PM
abit off center
cgarr's Avatar
Is the big snap ring still on the front of your crank at the dizzy drive gear? Is that a chip our of your alum pump gear?
Craig
G2Performance
Old 09-05-2009, 06:20 PM
Have you removed the intermediate shaft yet? Is that bearing parts from the shaft bearings?
Old 09-05-2009, 06:32 PM
Eastern Canada
The gears all look good with no chips. I will check the snap ring in the morning. Thanks!
Old 09-05-2009, 06:51 PM
356RS's Avatar
That one intermediate shaft bearing in the picture shows excessive wear compared the the main bearings. Waiting to see more pictures.
Mark Jung
Bend, OR
MFI Werks.com
Old 09-06-2009, 08:50 AM
Its not abnormal to see main bearings in excellent condition and intermediate shaft bearings worn down to the copper layer. We see excessive wear in situations where certain stiff, racing valve springs are used.
I'd ask what oil was being used and how often it was changed.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-06-2009, 10:00 AM
Eastern Canada
I've only owned the car for a few months. I bought it for $5,000 with no history but judging by the condition of the body and excessive rust on the rear inner fender and rockers, I know it was not taken care of. I own a 964 as well and took on this project first before I attempt a rebuild on the 3.6.
I will post more pics once I remove the oil pump.
Old 09-06-2009, 03:28 PM
If the engine was repaired but not split, say you blew a piston, swallowed a valve, etc and some junk was left inside it would find its way to the oil pump area and just rest there,.
I have seen that before.
Bruce
Old 09-06-2009, 06:11 PM
valve spring bits? the spring seat also has a lip that can get beat up, rounded over and broken off when a broken valve spring beats on it for a long time. seem plenty of them with no remaining lip at all.
206 637 4071
Old 09-06-2009, 08:45 PM
Eastern Canada
Well its not the bearings and everything in the case is intact... I agree the bits are probably from a previous repair or heads.
Time to order more parts from our host
Old 09-07-2009, 04:21 PM
911 tweaks's Avatar
great news!! s you proceed with your rebuild, post all of the progress here or if you start a new thread post that here also!!
Good luck & do you live anywhere near the Carnival hotel of univ of NB?? Spent a lot of time up your way w/ Baxter reps. Know Freddie Savoi??
Bob
I live for 911 tweaks...
Old 09-08-2009, 03:44 AM
Eastern Canada
I live about 5km's from UNB. Next time you visit ge me a shout
Old 09-08-2009, 10:35 AM
911 tweaks's Avatar
Derk... funny slip there on my last post... I ment to type Carnival Hotel OR the UNB. I believe that is the name of the hotel that has a carnival wheel inside it... it is located at a rotary very close to UNB... I have not been up that way since 92'... pm me if we need to discuss further as I do not want to interrupt this thread.
Bob
Old 09-08-2009, 11:25 AM
boxermania's Avatar
See if you can match the broken pieces by the way they broke apart, it might give you an idea of the diameter of the object and that should narrow the search down.
I do tend to agree with one of the posters in so far as it might be the result of a prior problem, where the case was not split and the parts found their way to the bottom of the case.
Al Morales
77 911 S (930 steel conversion)
88 BMW M3
79 Honda CBX
Old 09-08-2009, 02:48 PM
