Re-use head stud barrel bolts?
Is it OK/adviseable to re-use head stud barrel bolts?
Sure, unless you havent spent enough money..
Bruce |
Just examine them for a damaged hex surface. If they are starting to strip replace the ones that are bad. I have a bunch of old ones that I put back into service if I find a bad one on the engine I'm building.
72 Carrera RS replica, Spec 911 racer |
That's not a problem!
Didn't see any mention in Bentley or Wayne's book. I only stripped one. Thanks. |
