2.2 motor options
What would be the result if I put a 2.4/2.7 crank in my 71T. It has had the following modifications by the previous owner, 2.2E pistons and cylinders, Webber Carbs, and these modifications by me 2.2E cams and a 71 "E" distributor.
I know one of the popular setups is 2.2 S pistons in a 2.4 motor which bumps the compression. Will going " Backwards" have the same result? Replacing the crank give me a higher compression ratio, correct? Also,increased displacement, right? will it be a 2.4? any idea of Hp resulting in this conversion? Is there any reason not to do this? I have several cranks at lest one should spec out. Thanks, Rob |
You will still raise your compression.
You will probably have to trim your skirts to clear the counterbalance on the crank Your compression will come into the mid 9. cr Its all the same idea as the S If you got to buy a grind on a cam, buy a Solex grind unless youre turning the T cams to E which is less expensive. Bruce |
Mark S
You will also need to change rods, 2-2-2 liter rods will not fit a 2.4 crank and if they did would be to long @ 130MM which would raise you compression alright, for a millisecond until pistons hit the heads. You will end up with a 2.4E with T heads. I would estimate HP 140-150 @ crank if all is fresh.
I guess I should have consulted Waynes book First. Waynes top engine picks
2.2>2.4 upgrade 70.0mm crank, E pistons, 2.2 cylinders, E cam, Carbs , 2.2 heads, Disp.2.4,Ratio10:1 "This is the best upgrade for 2.2 engines as it essentially turns them into a 2.4L displacement. The 2.4 and 2.7 share the same crank, so these cranks are easy to find out of junk 2.7 motors. Using the shorter stroke 2.2 pistons means that the compression ratio is elevated to about 10:1. This engine runs fine on pump gas without twin-plugging." He did not mention Rods. According to Anderson The E and T heads have exactly the same specs, valve size,I46, E40 ports I32, E32 |
'71 911E Targa rebuild project, '82 SC, '85 911 M491 cab, '90 C4, '85 911 cab, '77 911 C3 (all sold )
A 2.4E =165 @ 6200rpm W/8.0:1, so I would think with 10:1 compression it would be closer to S specs A 2.4S=190 @ 6500rpm w/8.5:1, S ports are larger 36/36 Has anyone done this build and run it on a dyno? |
any updates on any of these builds
I once had a 2.2 with S cams and E pistons (in Germany). The car screamed on the autobahn . I may be following the same path but starting with a 2.4; E cams and 2.2 E p/c. Any results on any of these builds above?
thanks Marlin
Marlin Ness sadly no longer: 1967 912, 1971 911T, 1974 911 Targa, 1975 914, 1972 914 Eagle GT with V8 currently: 1972 914 Eagle GT with 3.2 Carrera, 1970 911T (964 turbo wide body look), 1986 911 Carrera |
