911 2.2 T targa
Originally Posted by The Dude View Post
Thanks again fellas.
Heinz - my deck height was 1.5 to 1.6 mm as measured around the perimeter of the piston. I used two 1mm shims to effect this. I was wondering if using two 1 mm shims sounded reasonable.
It depends. What machining was done on the case? With my rebuild the center flange was flattened and the cylinder bases fly-cut and I only had to go from a standard (0.25mm) to a 0.5mm copper gasket to come to 1.1 mm deck height.
Technically there is nothing wrong with using two gaskets and the thickness is not an issue but 2mm is sounds like too much. If this is to compensate for cutting the cylinder base there is no issue with the timing-chain housing but if it is to compensate for material removed from the center of the case this will end up causing miss alignment with the cam coverplates.
Old 03-18-2014, 06:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
Update/Question May 18th
I'm ready to put the heads/cam carriers on now.
Found a great post on pros/cons of how to do this (Head install sequence) along with a great video (Nick Fulljames fits barrel & cam carrier.wmv - YouTube). There are two parts to this video sequence. After studying this a bit, I think I'll do it like the video.
New issue: we are moving in a month to Dayton, Ohio. Anyone have a good machine shop in that area? I'd still like to pursue getting the heads ported before I bolt them on.
Also, I'm still shopping for a set of S (or equivalent) cams to match the rest of the build. Let me know if you've seen any.
As always, it's great to know I can post a dip$hit question and not have someone laugh too hard at me before giving a straight answer!
Thanks all.
Landon
Landon
- 1972 911T
Old 05-18-2014, 09:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
3 month bump.
Here we are in Ohio. Anyone know of a good machine shop near Dayton?
Landon
- 1972 911T
Old 09-08-2014, 04:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
(Almost) Final product.
In case anyone is still subscribed.
Landon
- 1972 911T
Old 10-05-2023, 06:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
Nice work on the car. And garage.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 10-06-2023, 03:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
