Porsche Crest 3.2 engine build
I ve never given it much thought about taking pictures of a 911 build. Some of the guys stop by and take a few for THE BOOK or want to see how its coming.
This is 3.2, std/std crank, new bearings, chains, ramps, rod bolts, nuts, Mahle P/C's, glaze broke with new rings, heads with all guides replaced.
I use the build style of sub-assembly so the heads are completely prebuilt, much like building the crank and the pistons are pre=assembled.
Bruce
Old 09-20-2009, 11:46 AM
3.2 engine build
The studs arrived and installed..and I hqve to go to work tomorrow
Bruce
Old 09-29-2009, 06:03 PM
onboost's Avatar
Bruce..
You're getting pretty handy with that camera Dadio. Nice theread, talk to you soon!
Paul
RGruppe #180
Old 10-01-2009, 08:10 AM
3.2 engine build
Moving right along, the cams came in at 1.38 out of 1.4, I had to move the right chain wheel 1 cog to get it in..
Bruce
Old 10-01-2009, 03:45 PM
3.2 engine build
Getting just a little further along
Bruce
Old 10-04-2009, 06:47 PM
onboost's Avatar
What's that engine going in when done?!
RGruppe #180
Old 10-05-2009, 06:46 AM
It will be for sale and I told it that there could be a nice home waiting for it in a red Targa in Washington DC
Bruce
Old 10-05-2009, 07:06 AM
3.2 engine build
Monday the injection was ready to install
Bruce
Old 10-05-2009, 08:07 PM
3.2 engine build
Seems like I ve been procrastinating but the truck needs rear brake lines and has me talking to myself as the fuel tank had to come down.
Bruce
Old 10-17-2009, 05:08 PM
OldTee's Avatar
Looks good. Don't forget the adell clamps for the chain tensioner oil pressure lines. I didn't see them from the angle of the picures. The lines will break in time without them.
Old Tee
all 911s sold
Old 10-18-2009, 06:03 AM
onboost's Avatar
Doubt he'll forget those... my God he's done enough of these over the years!
Bruce.. don't need one of these for the Targa, that o'l 3.0 is just fine..uh, once we get that CIS sorted.
If the timing had been right, it would've been nice to catch you on the front of this build and a couple special items that would have made it perfect for one of the other cars here!
Paul
RGruppe #180
Old 10-18-2009, 08:01 AM
Manassas, VA
lucittm's Avatar
What distributor is that with no adjustment? I thought those were only used on the EZ69 engines since the timing is digitally mapped.
Just curious and still trying to learn...
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Thats an 85 3.2. The
Old 10-18-2009, 11:25 AM
Thats am 85 3.2, The DME does all the mapping of the X,Y, Z coordinates with the engine sensors. The advance is available in the distributor but the spark control is in the brain.
Bruce
Old 10-18-2009, 11:27 AM
BReyes's Avatar
Nice lil motor coming together. I like the intake, with harnesses, nice (anodized finish) fuel rails, ICV looking pretty good. The rubber lines, sensors, micro switches, injectors can all be seen when the motor is out and illustrative.
Are you going to post on the cam timing process?
Regards,
Bernard
Old 10-23-2009, 09:32 AM
VMAX1's Avatar
That is Beautiful! Maybe, one day my 3.2 I am working on will look like that.
Old 11-06-2009, 10:11 AM
[QUOTE=Flat6pac;4958376]Seems like I ve been procrastinating but the truck needs rear brake lines and has me talking to myself as the fuel tank had to come down.
Bruce
Hi Bruce, I am sure i am to late, but why drop a gas tank. Why not just fish a new brake line next to the tank. I try not to drop a tank, because usually you end up with more problems. Just a suggesion
Old 11-12-2009, 09:12 PM
And I did endup with more problems. I didnt want to have 6 foot of brake line not retained and just floating. It was suggested and I looked at it.
Thanks,
Bruce
Old 11-13-2009, 04:47 AM
Its been a while and the cold has set in but its in the 40s a couple days and I ve dragged more stuff from the cleaners and did a couple engines along the way and including the muffler on my 930 to one that fits.
I have the muffler now and the cat bypass to be added maybe tonight. but I m still stirring with this.
Bruce
Old 02-03-2010, 10:08 AM
I have most of the major parts on it so I m going to close this section with this picture and open up the FOR SALE section for this engine. I bought it for the fun of building, been doing it for years as several people on Pelican can attest to, Its good for peace of mind and quiet in a hurried world.
Everyone, thanks for looking while I was building.
Bruce
Old 02-08-2010, 03:55 PM
